I made an offer on this and ended up buying it. It's hard to get a good image of the colour, the years have not been kind to the nitro colour which looks solid dark green or even black until you get very close. It is translucent green when you shine a light on it, I expect the colour would have been great when new. I've tried to get close to the actual colour in these images. Neck is 2=5 A and body is 2=5 TG. It definitely started out as a block logo Springy (can make out springy sound), that logo was removed and replaced with the goldstar fanatics decal. I think this was done in the factory, the remnants of the original decal are invisible unless you are looking under a bright light at a certain angle, had the owner not pointed it out I'd probably never have seen it.
Pups are VS1s apart from the middle U. All the screws, even the trem cover are gold (threads are at least). Nitro V neck. 2 piece body. It's scruffy but it plays great. I'd say Feb 83 for the build date can't be later given the block decal. I've got an ST pot to replace the volume, just need to find a middle VS1!
