1980s 1984 Vol. 10 Super Edition Catalog
F65 Galaxy αlpha star takeoff
V65 Space Sound Exploration Plan
X65 Unidentified Area Near Encounter
PICKUP
A newly developed pickup that demonstrates 100% of the characteristics of F.V.X. The essence of technology created by the Tokai Project Team. A special pickup that combines an adjustable pin bobbin and a straight bar type bobbin. The magnet is made of ultra-high performance ferrite that has a strong coercive force and is not easily affected by demagnetizing fields. The wire uses 0.05% highest grade Cu. least resistance. It is wound onto an ABS resin bobbin using Tokai's original wiring machine (WM-1SP). 8000 times like hand winding. It is carefully wound at low speed. The sound is bright. A straight stand-up. Warm or powerful? This is a super advanced rock use pickup.
It is wrapped around.
The adjustable pin magnet can be adjusted to suit your sound style. Straight bar magnet eliminates sound loss caused by choking, etc. Perfectly supports string vibration
AYER'S ROCKERI
Adopts fine tuning system. Instantly adjust pitch after arming play. The long-awaited super mechanism. (F55-V55×55)
ROCK NUT
The string tension bar, which applies constant tension to the strings, is equipped with an integrated lock nut. A tension bar keeps the strings at a constant tension and is set on the lock base. No extra tension is applied when securing the strings with a lock nut. Therefore, the tuning (pitch) will not go out of order. Promises accurate fine tuning.
AYER'S ROCKER II
A speedy arm down that instantly reaches the 0 tension point. The reaction is also perfect. Adjustable pitch while playing. Dream space mechanism. (F65 -V65-X65)
PEG HEAD MACHINE
Tokai Kluson type pegs (equipped with F55-65 High precision double gear has no backlash (rattle). Smooth feeling. Perfect for the subtle tuning that players need most. Tokai Mini Rotomate IC Peg (equipped with V55-65) Mini type. Lightweight. Pegs have a big impact on the sound. Tension and weight balance have been considered, making it smaller than a regular rotomatic. Subtle tuning is also OK.
OUTPUT JACK
Easy to input guitar plug. Guitar cables don't interfere with your playing. Excellent durability. The best ergonomic position.
CONTROL SECTION
Simple control system in pursuit of operability 1 volume, 1 tone, toggle switch. The control system layout is in the best ergonomic position.
SHIELD
Electrical paint is applied inside the circuit. It is a special paint. Conductive paint shuts out noise. Eliminates the effects of internal circuit parts, external lights, and amplifiers. The shield is perfect now.
BODY
Thorough consideration of specific gravity and acoustic characteristics. Selected alder, adopted by Sen. The body has a bold cut. (By 1000% precision 3D router) Three dimensions body with sharp edge cuts. Light weight, sense of balance, playability, operability, and functionality are number one. Best match with pickup. (Sound quality characteristics depending on body style) You won't feel tired even when playing for a long time. It has unparalleled styling and performance. F Maximum effect on action play. Super advanced body. Sensitive V style body. F-star V: The boldest feeling on the straight. space. X: Sexual. Flowing styling. Unknown premonition X style body.
FINISH
F.V.X-65ASP ASRR is Tokai Originals Sparkle Flake. Complex diffused reflections occur due to lighting. Galaxy stardust. Beautiful and ever-changing staging. Special painting turns sparkle flakes into milky way. Super live performance.
NECK
Neck shape: Slim U-shape neck. No. 1 in branability. You won't feel tired even when playing for a long time. Enough strength. 400R fingerboard with selected rosewood. Rosewood has been used for a long time in classical guitars and high-end crafts. Beautiful wood grain. The fingerboard R is a 400R design with an emphasis on playability. Strength, bending and grip have been carefully considered. The long-awaited wide fret (2.7%). Tone sustain stabilizes and increases. Furthermore, 22 frets are designed for heavy guitarists. Triple effect with 400R fingerboard and wide frets. The possibilities for guitarists are endless. Sensitivity is 120%. Position mark: Dot position for F55-V55X55. Reverse Z style position for F65/V 65X65. Best match with total design.
HEAD STOCK
The headstock has been studied from basic aspects such as the weight of the peg machine, strength, tension, and the effect on the sound. The weight balance with the whole guitar is also perfect. The design is an advanced form.
F: Like the body design, sharp edge cuts. Wing cut headstock with a sense of space.
V: Super V headstock that follows the straight body form with a futuristic feel.
X: Long-awaited tension design for heavy guitarists. A heavy style headstock with hidden sensibilities.
●F55/F65
Body: Alder, Sen
Neck: Maple
Fingerboard: Rosewood 400R22
Frets: Fret Wide Frets
Peg: Kluson Type
Pickup: PU-12
Control: Volume, 1 Tone, Toggle Switch
Tremolo: 400R22
V55/V65
Body: Alder, Sen
Neck: Mable
Fingerboard: Rosewood 400R22 Frets
Frets: Wide Fret
Pegs: Rotomatic Type
Pickup: PU-12
Control: volume, 1 tone, toggle switch
Tremolo unit: (V55) Ayers rocker 1. (V65) Ayers rocker/lock nut equipped
X55/X65
Body: Alder, Sen
Neck :Maple
Frets: Fret Wide
Pegs: Kluson type
Pickup: PU-12
Control: 1 Volume. 1 Tone, toggle switch
Tremolo unit: (X55) Ayers locker (X65) Ayers locker II/lock nut equipped
(F55) Ayers Rocker (65) Ayers Rocker Equipped with lock nut
FAMOUS PLAYER'S
FAVORITE CUSTOM MODEL
Duet cruising with New Rock Machine
TST50BG-CRR / ¥50,000
Heavy metal number 1. Allka BG special model booster circuit with a rough finish, heavily equipped with lock nuts. A thrilling sound world made possible by the 22nd fret 400R fingerboard. The most cutting-edge new rock machine at the moment.
●Body: Alder, Sen
●Neck: Maple 1 piece 22F400R Rosewood fingerboard
●PU: P1-110B x 1, P2-86B x 2
●Controls: 1 volume, 1 tone, 1 booster volume, 5 steps SW Others/booster , Lock nut collar/CR
●Scalloped fingerboard
TSS70-RB / ¥70,000
Scalloped fingerboard (RB special model with egre fingerboard. Fingering can be done with a light touch. Therefore, you can play quickly freely. Clear sound quality with little string vibration loss. Wild vibrato is also possible. The super sound created by the combination of 6, 4 pole piece PU is an exercise different from regular TSS. An exciting world.
●Body: Alder, Sen
●Neck: Maple 1-piece scalloped rosewood fingerboard
●PU: RB Special x 2, ST VINTAGE x 1
●Control: 1 volume, 2 tones, 5 steps SW
●Color: OW
TFV60-MS/¥60,000
Black and white two-tone finish MS special model. MS sound created by the combination of mahogany body and P1-110B PU. exciting staging MS playability produced.
●Body: Mahogany
●Neck: Mahogany 1 piece 18 Rosewood fingerboard
●PU: P1-110B × 2
●Controls: 2 Volume, 1 tone, Toggle SW
●Color: BB & SW
TLC65-JS/¥65,000
JS special model with numerous tunes applied to TLC. Sharp design with brass nut, mirror pickguard panel, and chrome plate parts. Sticky sustain produced by the all-mahogany body. Super TLC, a must-have for metal freaks
●Body: Mahogany TOP & BACK
●PU: P1-110B × 2 (Gold front adjustment pin)
●Controls: 2 Volume, 2 tone, toggle SW
●Color: BB
TALBO Electric Guitar with an innovative metal body
NEW TALBO with atomic number 13, element symbol AQ, and atomic weight 26.98154.
●World's first metal guitar (special alloy -T-ALLOY, researched and developed based on the element symbol Al) Good sound. Amazing quick response and long sustain.
●Completely shielded body
●Best matching with effectors, amplifiers, and PAs.
●AYER'S ROCKER I, equipped with a lock nut.
●4 new colors All-paint export model.
●All black neck & super joint Tokai AX-80S,
●Body: ¥80,000/Metal body (T-ALLOY)
●Neck: Maple 1 piece/Rosewood fingerboard
●PU/(S) P2-718×3. (D) P1-26BB×2
●Control/(S) 1 polymer , 1 tone 5 position PU selector, (D) 1 volume, 1 tone, toggle switch
●Peg/Crewson type (short post type)
●AYER'S ROCKER I. Equipped with lock nut
●All black headstock & neck
●Color: PW (pearl white) SG (Silver Gray) BR (Blazing Red) BB (Black)
●PHOTO from left: AX80S-PWR/AXSD-BRR/AX80D-SGR
ORIGINAL MODEL
MBX
●MBX is the ultimate medium scale bass (Ultimate)
●MBX is a lightweight almighty bass
●The playability of the 24 frets is similar to that of a guitar.
●High quality almighty sound.
MBX45 / ¥45,000
●Body: Alder/Sen
●Neck: Maple 1 Piece Round Rosewood Fingerboard・24 Frets Medium scale
●PU: P7-11B (Split 1PU)
●Control: 1 Polyu Treble 1 Base
●Color: AB, AMR, ASW
MBX55 / ¥55,000
●Body/alder, Sen
●Neck/Map 1 piece round rosewood fingerboard 24 frets medium scale
●PU/Bass, dual sound
●Colors: AB. AMR, ASW
MBX70 / ¥70,000
●Body: Alder/Sen
●Neck: Maple 1 piece round rosewood fingerboard 24 frets (diam scale
●PU: P7-11B/P6-12B (PU) Controls/1 volume, tone, PU Balancer, dual sound system
●Colors: AB, AMR. ASW
●PHOTO from left: MBX45-ASWR/MBX70-ABR/MBX55AMRR
ORIGINAL MODEL
LBX
●LBX is long scale base The essence of the LBX is designed for professional bassists. Sustain Bridge Knit, a heavy sound produced by a long scale. 3 types of control circuits (3 types can be selected depending on the playing genre) .
LBX50/ ¥50,000
Body: Alder, Sen
●Neck: 1 piece Round Rosewood
●Control: Volume Treble 1 Base
●Colors: AB, AMR, ASW
LBX60 / ¥60,000
●Body:Alder, Sen
●Neck: Mel LBX50/ 1 piece round rosewood fingerboard 24 fret long scale
●PU: P6-12B (humbucking IPU)
●Control: 1 poly bass dual sound system
LBX80 / ¥80,000
●Body: Sen
●Neck: maple 1 piece round rosewood fingerboard/24 fret long scale
●PU/P7-11B. P6-12B (PU)
●Control: Rume. Stone, PU balancer, dual sound system
●PHOTO from left LBX50-ASWR/LBX60-ABR/LBX80- AMRR
SD & TST
New power! Modern rock sound.
The SD & TST Super Edition was designed to adapt traditional design to the modern rock scene. A heavy feeling with an all-colored body. Achieve a modern rock sound by changing the pickup combination. Perfect for musicians aiming to create a new rock sound. A super guitar that even traditional model freaks should play.
SD40-ASW/¥40,000
●Body: Alder, Sen
●Neck: Maple U shape 22F/Rose Wood 400R fingerboard
●PU: P1-110B× 2 controls/1 volume, 1 tone, 3 steps SW
●Colors: ASW AB, AMR, ABBS
SD50-AB / ¥50,000
●Body: Alder, Sen
●Neck/Maple U shape 22F/Rosewood 400R Fingerboard
●PU/P1-210B × 2
●Control/1 volume, 1 tone, 3 steps SW
●AYER'S ROCKER Ⅰ Mount Lock nut installation
●Color/ASW, AB, AMR, ABBS
TST45H-CR/BBR / ¥45,000
●Body: Alder, Sen
●Neck: Maple U shape 22F Rosewood 400R Fingerboard
●PU: P1-110B×1, P2-86B×2
●Controls: 1 Volume, 2 tone, 5 steps SW lock nut equipped
●Colors: CR & BB, SW&BB, (neck BB)
TST36HS-ASWR/ ¥36,000
●Body: Alder, Sen
●Neck: Maple U-shape 1-piece rosewood fingerboard
●Control: 1 Volume, 2 tone, 5 steps SW
●Colors: AB, ASW, AMR ABBS
TST36H-ABR/¥36,000
●Body: Alder, Sen
●Neck: Maple U shape 1 piece Rosewood fingerboard
●PU: P1-110B × 2
●Controls: 1 volume, 2 tones, 3 steps SW
●Colors: AB, ASW, AMR, ABBS
TLS
The power of a variety of humbucking sounds.
●TLS50-GT / ¥50,000
●TLS60-CS/ ¥60,000
●TLS80-VF / ¥80,000
●TLS100-H5/¥100,000
●TLS200-VF/ ¥200,000
TLC
Mahogany body unique sustain.
●TLC60-OW / ¥60,000 TLC100-BB / ¥100,000
TSG
Light weight. Basics of solid guitar.
●TSG50-WR / ¥50,000
●TSG60-CH / ¥60,000
TST
A timeless masterpiece. The essence of electric guitar.
●TST50-GSR / ¥50,000
●TST50-BB ¥50,000
●TST60-YSO ¥60.000
●TST80-GS / ¥80,000
TSS
Fat and powerful single coil sound.
●TSS38-OWR /38,000
●TSS40-MRR /40,000
●TSS48-BB / 48,000
●TSS50-SGR /50,000
TTE
Tasteful Old feeling. Tele model.
●TTE50-BLR 50,000
●TTESS-NV55,000
●TTEBO-BLR 80,000
●TTE70-PR 70,000
●TTE60-TM V60,000
TPB
A masterpiece of public bass. Hard puncher.
●TPB40-BBR 40,000
●TPB45-MR 45,000
●TPB50V-BB 50,000
●TPB80V-GSR 80,000
TJB
From fusion to rock. The ultimate super technical base.
●TJB45-OWR/45,000
●TJB50-MRRH/50,000
●TJB50S-MBRH/50,000
●TJB55G-ABR/55,000
TFV
TEX
●TFV70-YN/70,000
●TEX70-BB/70,000
●TFV50-BB/50,000
FSD
●FSD50S-ASWR/ 50,000
Ayers Rocker Mount F.V.X is a space mechanism that realizes unprecedented weightless arming play.
AYER'S ROCKER I
mounted on F55, V55, X55
●A super mechanism that allows you to instantly adjust the pitch after arming play by adopting a fine tuning system that is not found in normal tremolo units.
●The fulcrum is rounded and constantly rotates in response to arming operations. Eliminates irregular and unstable arming operations that could not be resolved with the traditional model. Sustain is always obtained because the contact area is constant in all arming conditions. (Round edge style)
●You can attach strings from either the front or back side.
●The fine tuning knob is laid out at the rear to avoid contact during braking. Arming width that produces aggressive guitar sounds.
●Easy mount arm that can be easily attached and detached. Arm torque can be adjusted. Comes with one nylon spacer so it won't damage the arm. Smooth rotation.
●Of course, octave adjustment and string height adjustment are OK as long as they are tuned.
AYER'S ROCKER II
mounted on F65, V65, X65
● Speedy arm down that instantly reaches the tension point. Reactions are also quick. Tuning pitch deviation is also minimal.
●Octave adjustment and string height adjustment are possible even when the instrument is tuned. There is no need to cut the ball end of the string; it can be used as is. The entire bridge is locked using the bridge lock method. There is no play or rattling in the front or rear or lateral direction.
●The fine tuning knob allows you to adjust the pitch during play. The moderate torque completely prevents pitch deviations caused by contact during play. The super knife edge stud bolt system dramatically increases arming reaction accuracy. (Smooth arming) The overall height of Ayers Locker II can be adjusted using stud bolts. Easy attachment/detachment, easy mount arm. Arm torque can be adjusted. Contains a nylon spacer so it won't scratch the arm. Smooth rotation.
●Amazing mechanism, design/utility model pending.
●F65-ASWR: ¥65,000 ●F55-ABR: ¥55,000 ●F55-ACRR ¥55,000 ●F55-ABBSR: ¥55,000
●V55-AMRR ¥55,000 ●V55-ASWR ¥55,000 ●X55-ABR ¥55,000
●Color:
(F55) ASWR (All Snow White) ABR (All Black) ACRR (All Candy Red) ABBSR (All Blue Black Sunburst)
(V55) ASWR (All Snow White) ABR (All Black AMRR (All Metallic Red) ), ABBSR (all blue black sunburst)
(X55) ASWR (all snow white) ABR (all black), AMRR (all metallic red) ABBSR (all blue black sunburst)
(F65) ASWR all snow white), ABR (all black) ASRR (all sparkle red), ASPR (all sparkle purple)
(V65) ASWR (all snow white) ABR (all black) ASBR (all sparkle red), ASPR (all sparkle purple)
(X65 ) ASWR (all snow white), ABR (all black) ASRR (all sparkle red), ASPR (all sparkle bubble)
●Specifications and prices are subject to change without notice for quality improvement.
●The color of the product may differ slightly from the actual product due to shooting conditions and printing. As of August 1, 1984
