Thank you for waiting. The original, TOKAI's proud hand-written spec edition.
LS
LOVE ROCK SERIES
The perfect neck and body structure has now surpassed the original... and whispers have begun to emerge.
●Headstock & Peg
The naming of the ``Love Rock'' model is particularly impressive on the small headstock with an elegant and tight head type. No matter where I look, I can't find such a beautiful woman these days. And if you get single knurl (Icob) Kluson type pegs, the old files will be even happier. Isn't the bush type resin knob very cool? In terms of performance, we have thoroughly researched and upgraded the Kluson peg, resulting in a high-precision peg with double-thread screws that does not rattle. Look at the yoke from the front and back of the headstock and you'll be amazed! We've produced a good-looking face that will make you feel like you're getting a lot of attention! It perfectly reproduces the elegant style and flavor of the Old Standard. This is the birth of a love lock model worthy of being called Evergreen.
●Neck & Head Angle
The now familiar mahogany piece neck. Needless to say, this was the first time it was adopted in Japan. This is a natural thing to do if you're using an old model and are going to do Rika. (At Tokai, it is used in all models except for the cost performance model LS50) This piece neck made of delicate craft work that Tokai is proud of not only has the transmission performance of the past, but also has excellent strength and feel against the sizing screw. He is No. 1 in the world ranking. There are also two types of neck head angles. The LS 50 and 60 models have a 14° head angle, and all LS70 and above models have an 18° head angle. In addition, this bed angle has been the subject of much controversy as the Traditional Model is nu! No, it's 18! Gatokai decided on 18 after researching the 1958 model and the 1960 model. If you are interested, please do your own research.
●Fingerboard & Fretching
Craftma , an outstanding woodworking technique, is here as well. All models use rosewood for the fingerboard, and the position marks, inlays, and fretting are perfect. The frets are the same width as the old one, 2.7m wide, 0.quymo high fingering, and bending is smooth.
There are two types of fret edging:
① over binding (LS 50, 60, 70) and
② fret edge binding (adopted on all models over LS 80). Both finishes are excellent. By the way, the neck width is 43mm at the nut and 52.5m at the 12th fret, both of which are designed to be easy to grip. It has a super neck specification that perfectly meets the needs of professional guitarists who make full use of high technology.
●Body
``Now let's move on to the elegant and beautiful arched top body'' ``Tokai LS Series Vintage'' 3 types of body construction: <Standard> <Special>.Thorough analysis and research of old standard materials. The body was developed by the project team.Vintage model: The vintage model is a perfect replica of the Tramoku Standard, which is used by all the world's top musicians.It is made of curly maple, which is rare in the world. Completely solid veneer 2-piece top with bright tiger stripe cross grain that will make you drool.Of course, the back is made of mahogany veneer (LS200V. 150V.120V) And the public model LS100V has tiger stripe material. Laminated 2-piece stock, mahogany back body. live in japan “The guitar freaks out there are really stupid.<Standard model>:758 Book-matched map that is exactly the same as the standard model material
■The original model with a rustic top and mahogany back. -Sae Mazzao Construction. Especially for LS80 and above, all the backs are one piece.
■High-grade mahogany with specially selected maple spies top. This super body provides good high-frequency response, making it comfortable even at low volumes. This reproduces that sound where the sound expands and expands. "vinegar
●Special model
Rare, produced in small numbers from 1955 to 1958. This model has a top and back made of mahoganino pieces. "It's called the mahogany standard. You can't taste it with maple. "It features a sticky sustain and a bluesy light sound. ・Joe Walsh has already used it and it sounds great. Demonstrates its charm in blues rock, southern rock, and hard rock.
■There is no doubt that it is. This rare model is about to become One of a Kind. You've entered the third realm.
● Arched top
Now, the last part of the body explanation is the arched top, which instantly increases the perfection and charm of electric guitars. Have you ever noticed something when you look at the arched top of the Old Standard or Toukite S series? Yes, it is actually an arched top, but if you pay close attention, it is flat from the pickup mount to the bridge and tailpiece. It has become. I think many people have noticed this, but this is also the reason why the beautiful form of the arched top appears and disappears due to the reflection of light. Tokai is the only model that is such a perfect replica of the original. It's easy to tell by looking at the flat bottom of the mounting ring (escutcheon).
●Pickups
As I've explained so far, pickups only work if you have the perfect hardware. And it shows its true potential with the characteristics of the Perfect Body Ga pickup of the Rera series, bringing out 100% of its power. Even if you mount a good pickup on a shoddy body, you won't get the perfect sound.
The LS series has a total of seven types of pickups, and each model brings out its full potential and brings out the sensibilities of guitarists.
There are three types of newly developed pickups to recreate that ‘57 year PAF: LS Vintage><LS Vintage MKⅡ><LS Dynamic). Even the square window has been recreated, and the zebra bobbin, covered type, zebra bobbin, open type, and double cream bobbin give it an old-fashioned feel.
Finally, Shiraro also has a single coil pickup. Field! Reproduces the laid-back ‘56 sound.
LS100 or more Above is DiMarzio PAF, the well-known king of replacement pickups. It is structured around.
●Mounting ring
This is common La escutcheon. At Tokai, we purposely call it a mounting ring. given name Please pay attention not only to the name but also to the shape. Also for arched top However, the bottom of the mounting ring is flat. Just now It's already explained. The charm of a perfect replica of the hold standard is alive here too. In particular, the height of the rear pickup is also the same as that of the current Les Paul. Much higher than that. The mounting ring has exactly the same dimensions as the old one. The coil plays hard even when the pickup is modified to an open type. Therefore, it provides perfect protection without being scratched. LS series uses this mounting ring on all models. saucer
●Knob & Switch Knob
Every detail has been perfectly reproduced. This is also part of the demon charm of the Shira series. It's all the same material as the old one I'm glad that it's made of. Gold top hat shape, so-called The saucer knob promises speedy and reliable action. and s When it comes to Ichnobu, it's the ultimate. Thorough analysis of old ribs and original Adopts the same top secret material as Naru. Time travel through many years at once The old color knob was beautifully completed. First appearance in Japan Needless to say, the deep, good-feeling knob is perfect for talking. Unique to Lee. It can be called a modern miracle.
●Bridge & Te
The number of pieces/special spec parts continues to grow. Bridge & Te The ring piece is also a complete replica, the bridge material is brass, and the tail piece is It's made of die-cast aluminum. The shape is also the ‘58 type and is similar to the current Les Paul. It's a little different. Please note that the center bulge is located slightly backwards. I want you to take a look at it. It's a really small thing, but if we go this far, we can It raises the level of perfection.
●Color
Vintage model has 3 colors VF/OS/CS, standard model GT/CS/BS/OS/BB And the rare color all gold (AG), the special model is OR・ Both ON and GT are available. Select according to your sense and preference I want you to. Special finish in which all colors reproduce the Garde color. It's Yu. Others/If you pay close attention, you will find that the old color has a really good taste. The shape of the strap, buttons, pickguard, and screws including the color finish Truly traditional Gibson-like. LS series is old standard It conveys the feel of the guitar perfectly and shocks many guitarists. It's on. Supported by the policy of Quality before Quantity The LS series, which represents the modern Tokai electric guitars, is a new support. He is worthy of leading the music scene. A real hold feeling, even for you...
