WB Bass Models
I hadn't noticed these before.
1989 catalog
WB750 WSR (left)
WB680 BBR (right)
SN 227225
Interesting to see a 1989 model wit a 22xxxx serial number.
[Used] Tokai / WB750 Walnut Satin [3.43kg] [Ikebukuro store]
This is the 26-fret WB750, an original shape model from Tokai Musical Instruments, a long-established Japanese manufacturer, Tokai.
Archtop ash body, maple neck, rose fingerboard, 26 frets, PU is TOKAI's original L.WHITE pickup JJ layout, 2Vol/Tone passive specification, TOKAI's original bridge is installed by drop-in processing.
Usage (paint peeling off on both sides of the nut, scratches around the head, dents on the elbow, scratches on the horn on the 4th string side, small scratches around the body, scratches and scratches from playing, gloss on the back of the neck and top of the body due to being played), There is some external damage such as cloudiness/bits on metal parts and screws.
It has been set up (cleaning, string replacement, rod adjustment, octave adjustment, string height adjustment, and fret alignment) when it arrived, the fret peaks are at a height that is comfortable for playing, and the truss rod is almost finished and is in a forward-warped state.
*Not covered by neck warranty.
Product rank: C+: Repair required depending on purpose of use
Attached case: Soft case
Accessories:
Serial number: 227225
Weight: 3.43kg
Used Warranty: 12 months
