ayrguitarist
Active member
- Joined
- Oct 26, 2023
- Messages
- 38
- Reaction score
- 27
Bought this a couple weeks ago, and though I'd share it with the fine folks here.
Anyone know about this Piare brand? Or have one?
I don't know much, if anything, about the Piare brand, but it appears from some googling, that it was possibly a store brand for Ishibashi (similar to Mavis, and more maybe?). These appear to be much less common than the Grandy and Mavis LC models, and I've only seen a handful of them sell on Yahoo Japan over the past 10 years.
First off, this guitar was probably one of the dirtiest and beat up guitars I've ever bought. In my top 5 for sure. But in the listing, it appeared that there were no headstock or heel cracks, and mostly intact. And it being made by Tokai, it piqued my interest, since I wasn't able to find much info on them online. It arrived to me even more filthy than I could imagine, with the jack plate destroyed, the pots seized, lots of pitting and corrosion on the gold hardware, some missing screws and knobs, and the D string bridge saddle was missing.
But I could immediately recognize that it was made by Tokai, by the serial number format, and some other tell's.
It's basically a 1985 LC-60 with the Piare badge, and proper split diamond inlay, on the headstock. It could be a 55 model (like the Grandy). And also similar to Grandy, I'd guess the model name could be PLC (i.e. TLC for Tokai, GLC for Grandy, PLC for Piare... but this is just a guess though).
It has:
After lots of cleaning & polishing, replacing the pots, switch, knobs, pointers, jack plate, and some screws, it's in playable condition.
The frets have lots of play wear, and also had some string indents that I needed to file & polish out. Judging by the amount of play wear on the fretboard and frets, it was likely someone's main player for awhile, and it plays that way.
The pickups sound pretty good to me - although I've got it strung up with heavy gauged strings and tuned to C# Standard with a G# on the bottom string, and I didn't play it before cleaning (it was unplayable).
Here's the interesting thing, although I replaced the pots, it came with what appears to be the originals installed. The pot codes read Feb 1988 for the volume pots, and July 1987 for the tone pots. So it's like this was made with a 1985 body, sometime in 1988? The strange thing is that I also have a Mavis LC custom, with a 1985 serial number, and it also has pots that are newer than 1985 (I don't have any pics of those pots, but I'll check sometime again soon).
The other interesting thing is that the headstock angle is steeper than my 1984 Tokai LC-60. I don't have a way to measure the actual angle, so I'm not sure what the angles are, but I read on the Faber page that the LC-60's used 14 degrees, while the LC-100 and LC-110's used 18 degrees.
Would love to hear if anyone has more info on these, or has one.
Here's some pics:
It has:
- Mahogany neck (not sure the number of pieces, likely 1, and I can' see a heel cap or headstock ears)
- Basswood body (not sure the number of pieces, but likely 3)
- Dyed rosewood fretboard
- 22 medium jumbo frets with fret edge binding (fret nibs)
- Acrylic pearl block inlays
- Bone nut (looks like bone to me - although this nut is pretty busted up)
- 2 gold covered humbuckers (8.15k ohm range for both) - unknown model, but similar to the 1980's Tokai PAF's (I haven't removed the covers to check the magnets yet)
- Japanese made gold plated non wire ABR style bridge
- Japanese made gold plated aluminum tailpiece (it's really light)
- The original switch knob was amber, and the original jack plate was the 2 ply like Tokai used (black on top, white on the bottom)
- Weighs 9.68 lbs
Here's some pics:
