Special Order 2012 Flametop Wine Red LC
SN 1228043
[Used] Tokai LC Model WR Order 2012 Tokai Les Paul Custom Type [Maintained]
Description of item
[Product Description]
2012 LC Model is now available from Tokai!
LC model with wine red color and flame maple top!
It was not listed in the catalogs of the time, and is probably a model sold as a shop order or some kind of limited edition item. From the specifications, it seems that it was made based on the Vintage Series LC107 at the time, and compared to the mahogany body and rose fingerboard LC107, this model has been changed to a flame maple top and ebony fingerboard. Coupled with the coloring, it has a very luxurious look. The pickup is equipped with PAF-Vintage MK2S. You can feel the tightness typical of a Les Paul Custom with a crisp high range, making it a very easy to use guitar whether clean or distorted.
There are some scratches and signs of use, but you can still play it!
Please consider it!
[Specifications]
■Body material: Maple/Mahogany
■Neck material: Mahogany
■Fingerboard material: Ebony
[Product condition]
■Exterior: There are some signs of use such as scratches, dents, and deterioration of the plating of metal parts.
■Remaining frets: Approximately 80%
■Neck: Flat
■Truss rod: With plenty of room
■Nut: No problems at present. (It has been replaced with bone material.)
■Electrical system: Currently there are no problems.
■Case: Soft case (there is some tear on the shoulder strap)
■Weight: Approx. 4.42kg​
