The Earliest Hard Puncher Basses
I have this one. I believe it is from 79, otherwise correct me. This is a low end model 40 as you can see on the neck stamp. The tuners only have 3 screws on the back vs 4 screws on higher models. The bridge has brass on higher models, mine do not. Apart from that I do not know what the difference is. Maybe the pickups ? Does any one knows? Anyway it is 100 % original, even the Tokai bag. Plays wonderfull and the sound is in my opinion amazing.
Does any one know if the pick ups are the same on Hard Puncher bass model 48- 60- 80.
What is the difference ? Tuners, bridge, saddle, wood,...ect..? Thanks
1979 Foldout catalog
Note the A & B pickups among other things. Typically 60 and up had 4 screw tuners, 80 and up had lacquer.
just received this bass. # is 800182,sold as a 65 but no stamp on neck. Neck is inked with either 6 maybe 8 hard to say, pickup cavity and neck cavity both stamped 8=18 N, which would be early production ? Pickups are stamped B, output 10.5K
Yes. Very early production. Super cool!
And if there’s no “A” stamp then probably not lacquer so it looks like it’s a PB65N.
Sweet bass!
Also, the serial numbers on the PB models used a different scheme than the ST guitars in 1978.
The PB guitars start later than the ST which began before the end of 1977. Very confusing.
ST guitars passed your serial number count (182) in 1977.
Your bass was made in August 1978.
Super cool for sure.
Early Springy serial numbers:
1977:
7000186 ST?? (Peter Mac provided)
7000131 ST42 BB (CliffsGuitarWorld)
7000108 ST?? YS (CliffsGuitarWorld)
7000105 ST50 OW (Peter Mac provided)
7000040 ST42 YS (Hiro)
77000011 ST60 YS (CliffsComicWorld) *Note Serial starts with "770" and not "70".
