81年製 Tokai Cat's Eyes CE-1200S オール単板 ... - ヤフオク!
This is a Tokai Cat's Eyes CE-1200S that appears to be made in 1981 based on the serial number. At first glance, it only looks like CE-1200T, but the stamp on the neck end only reads CE-1200S, and there is no documentation, so I don't know what is different from 1200T. You can also see a faint letter A-like stamp on the top right of the S stamp. Specifications include a solid spruce top, solid rosewood side and back body, mahogany neck, ebony fingerboard, ebony bridge, and Tokai's original Kluson type pegs. A triple O-sized book with Martin's 000-28 motif that is easy to hold and handle. The reason why I chose this is that there are multiple cracks in the wood, and first of all, there is one joint in the center area behind the bridge, three on the side of the 6th string of the fingerboard, and 2 on the side of the 1st string, all of which are in an unrepaired state. Also, the back is whitish overall and the paint is becoming cloudy. In addition, there are some scratches, small scratches, and small scratches on the back of the neck. The frets are about 70% warped in the neck and can be used in this condition as long as you don't worry about the above points. Accessories include genuine hard case. Please treat it as junk so there will be no claims or returns. (Added October 23, 2023 19:56)
