blake375
I'm currently working on a song that requires the use of a 24th fret on the high E string; not having any 24-fret guitars to hand, I thought there must be a way of improvising a 24th fret on my Goldie. The way I figured out of doing it is so simple that even though I came up with it myself, I'd be very surprised if it isn't already well known amongst strat-users.
I simply took an allen key (the regular size for floyd rose trems etc.) and filed the top edge down a bit like this:
Placed it on the neck pickup like this (magnetism holds it in place):
An then added a bit of gaffa tape to make sure it stayed put:
Bob's your uncle. You can adjust the fret height by adjusting the pickup height. On my guitar it is almost the perfect pitch - play with vibrato and it sounds just fine. Just as well I didn't need the 22nd or 23rd fret though. Bending is awkward, but if you spent more time filing and polishing than I did I'm sure it would work wonders. Better than switching guitars or necks just because you need to hit a high E now and then.
