Unfinished Love Rock Factory Reject
Tokai トーカイ B級 レスポールタイプ ボディ ネ... - ヤフオク!
Made by Tokai, Class B Les Paul type body and neck.
I was planning to assemble it myself, but I'm selling it to reduce the luggage I'm moving.
The reason for the B grade is as follows.
Image 4 There is a slight gap between the mahogany joints of the two pieces, but the gap is so small that even the wood filler can't get in.
Image 5 There are knots on the back mahogany
Image 9 There is a worm-eaten hole on the back side of the base of the head, but it can be repaired with wood filler.
As you can see, the processing precision is unique to Tokai. (Especially the structure that firmly fixes the neck with the stepped part of the neck, and the processing of the neck (image 2) (the cavity is carved diagonally to match the neck). Made by Tokai without
The top frame is pasted. Please note that it is not solid.
