Hi all,
I need a replacement tremolo arm for an original Tokai Steel Block circa 1987.
...a little back story.
I removed the original tremolo/bridge on my 1987 Goldstar ST50 in the mid 90's due to corrosion etc (this guitar was "hammered" over 4 years constant touring with The Pretty Things) and the wear on the saddles was causing string breaks too easily.
I replaced it with a Gotoh one that has done me well since - though I kind of fell out of love with the guitar as the Telecaster became my Number One.
Recently I have been reading about the steel verses zinc blocks.
I had "assumed" that the replacement Gotoh was steel too - but was surprised to find it is zinc - so I swapped the Tokai steel block back and bolted it to the Gotoh top plate and saddles and reinstalled.
I now see why I lost interest in the guitar - there is life back in it with more noticeable upper harmonics, even acoustically!
Only problem is the Gotoh Trem Arm has a smaller diameter it seems and does not screw in.
Any suggestions?
...and sorry for the slightly convoluted post, but felt it good to report my observations re steel/zinc.
cheers
Barks
Any suggestions?
cheers
Barks
