Hi all,
I'm looking for a tremolo arm that will fit.
All the newer ones that I have found locally are a little smaller in diameter so the thread does not grip.
Backstory - I replaced the entire bridge in mid 90's with a drop in Gotoh replacement as the original steel saddles had corroded so much.
The Gotoh had the alloy block though at the time I did not really grasp the significance of the difference between steel and alloy.
I have put the original steel block back in and the tonal difference is NOT subtle but alas the Gotoh arm does not fit.
Any help appreciated in sourcing a good replacement would be greatly appreciated.
Barks
Barks
