A
Anonymous
Hi MIJvintage and thanks for the links.
It still does not answer how those caps made their way into an LS320.
Rup
Rup
rgrafend said:Hi MIJvintage and thanks for the links.
Rup
MIJvintage said:I would strongly consider having this one 'completely' wired as an original '58-'60 burst
villager said:les paul forum..
do a search for 59 wiring
Rustyslide said:Despite what the diagrams show, you only have to move the wire on the volume pots - the wiring at the tone pots is functionally identical between 50s and "modern" (which has been used since the early to mid 60s, IIRC).
stratman323 said:Could somebody please give a VERY simple explanation of the difference between thses two ways of wiring, and the advantages of each of them? I'm sure I can't be the only one who is baffled by this. Thanks.
stratman323 said:Which one does Tokai use on the LRs?
ganzua said:Rustyslide said:Despite what the diagrams show, you only have to move the wire on the volume pots - the wiring at the tone pots is functionally identical between 50s and "modern" (which has been used since the early to mid 60s, IIRC).
Yes, that's right. I thought the 59 mod that everybody is talking about was a particular mod only for the 59s and not the same that the one called "vintage". :lol:
Here http://www.acmeguitarworks.com/Les_Paul_Assembly_Without_Pic_P1776C185.cfm there is a very good explanation They also state that the name "vintage" is wrong because some Les Paul from the fifties were "modern" wired.
:lol: My LS85f came from factory with the two volume pots operating as master volume when switched to the middle position. It must be called the "too much sake yesterday" wiring mod.
