TOKAI トーカイ L.WHITE SDS DRIVE ラージポール... - ヤフオク!
Specifications: A single coil mounted on the front of the 1986 TOKAI JSD-603.
A single coil called TOKAI SUPER DRIVE was sold for 15,000 yen at that time.
In the catalog,
he is an alnico Φ6 big pole piece and a formidable power born from OFC wiring.
Sharp and bright sound with waist.
is what it reads.
This PU was originally developed by Tokai in the mid-80s.
Lawrence White seems to have been involved in the development, so it's called L.WHITE.
It is a PU that uses OFC (non-oxidized copper) for the coil and has some manual winding, which is quite costly.
Single coil featuring coverless, copper foil shield, decapole piece and alnico magnet.
High power single coil.
The resistance value is 11.81kΩ.
It will be for hanging with a pickguard.
The length of the lead wire is about 20 cm.
Condition: The appearance is a bobbin without a cover and a large pole piece specification, so it is a PU that is prone to aging.
The pole piece is slightly rusted, but the bobbin has not deteriorated so much and can be used without problems.
The L.WHITE logo is about to disappear and can be easily removed with a wet cloth, so it may be better to remove it when you get to this point.
Mounting screws and springs are included.
Shipping: Yu-Packet 210 yen.
Normally, OEM PU manufacturers are equipped with various names for each brand, but this is a TOKAI original PU.
In the catalog,
is what it reads.
