dalemajd said:
yeh so where can i get some good bumblebee repro caps.
and im in Australia if that helps.
The advice above about using some other paper in oil caps is good advice, the Russion ones can usually be had pretty cheap.
I'm not sure there are any true bumblebee repros? No, actually here are some:
http://www.ezramusicshop.com/pd-1956-60-bumblebee-repro-capacitors-pair-022uf-400v-pio.cfm
But I have to say that these will contain the same Russian paper in oil caps that you can find on ebay, without the striped plastic outside bit. RS Guitarworks also carries these and I'm sure a few others do too.
Try searching worldwide on ebay for "Sprague" this usually turns up some Vitamin Q's and other cheaper ones as well as vintage used Bees.
