cherryburst
A small problem with my LS125 - I've been experimenting with different string gauges and the set-up in general. One problem I've noticed is that I can't get much relief in the neck, even with the trussrod backed off fully. This means that the low E string buzzes badly unless the bridge is hiked up quite high. I think that installing a new, better cut nut will improve the problem, but I just wondered if any of you guys had experienced this problem? Any comments or help appreciated.
