Tokai SG of Unknown Model
8bit Barry
I bought a Tokai SG yesterday. Seller didn’t know the model, Made in Japan, 2007.
It’s got a fabulous vintage C neck, one piece body, Gotoh pickups, F and R stickers on them.
I thought it was an SG 75 from the catalogue entry for that year, then inside the case I find a neck sales ticket that says ‘SG175 now known as SG212’, which must of been from a dealer.
With my other Tokai Reborn’s it has a stamp with the model number on the neck. I can’t find anything obvious.
Is the model number marked anywhere on the body / cavity? How can I work it out?
And the fret board stamps with model numbers ended in 1980 as I recall.
Check the neck pickup cavity. May be in there.
Many thanks - it’s weirdly got one CTS pot, the other ones don’t seem to be the same make.
I’ll check the neck cavity and report back.
I wonder if it’s an SG-155 then?
I noticed the specs only mention the volume pots as CTS. Does the solder look like it is original on the others?
And with the model number, I pay more attention to specs than model number.
Sounds like yours has a one piece Honduran mahogany body and lacquer finish which is awesome.
I will check. I’ll change strings and take some pics of the pickups / cavity and controls. It’s sounds really loud acoustically and has such a superb neck.
I’ll be stoked if it’s a premium series guitar.
I have the P90 version of this bought in 2004, a USG-P90 and it’s got a D-shape, which is also very enjoyable, but this is really class. Feels very vintage.
Here is the other possibly MIJ SG in 2007, the SG75. The rest of these are Chinese I believe (50,000 yen and under).
I just noticed it is also a one piece body.
It’s so hard to tell if it’s one or two piece, I’ve been studying it for a while this evening and I’m still not sure!
The back has no definite split, but if I study the lacquer.
Nothing in the cavity…
I don’t understand these two screws, the lacquer seems to suggest a different tail piece has been fitted at some point as it’s made a square impression.
Treble pot is CTS branded, the others are not
Is it supposed to have a higher pick-up ring on the bridge pick-up?
I’ve restrung it with 10’s and it’s SO much better playing than the 9’s that were on it.
Hmmmm. Those pickups are some that I hadn’t figured out. I can’t say for sure if those are original MK2 pickups.
Check out this thread:
Tokai Humbucker Models & Resistance
And get a very bright light like a headlamp to search for a seam.
And I guess we just skipped over the part about the head stock.
Can you post a picture with the serial number and the "Made In Japan" stamp?
SG75 seems to have MK3 pickups. Hard to tell because the catalog scan I have is blurry.
The pickups you have I think may be the MK3 pickups.
That note in the case screwed me up and sent me on a wild goose chase. I had originally thought it was a hang tag and so I made assumptions.
It is seeming like it is probably an SG75 as you originally thought.
