Shenandoah MH00028 Natural [SN M024063] [06/13] | Reverb Brazil
Shenandoah MH00028 is now in stock!
It is believed to be a model made by Terada Gakki after 1994, when a certain music store obtained a license from Martin. Veneer spruce top, rosewood SIDE/BACK body. Mahogany neck, rosewood fretboard, and a black honey bridge are the wood materials used. Scalloped X bracing (there is a shaving on the large brace under the bridge rather than the whole body), long saddle, approximately 42mm nut width, V-shape neck, and medium scale.
The body is generally dotted with scratches and dings. There is also a slight chip on the tip of the head, but it is not visible from the front, where it tends to be seen. The frets have a few string marks in the low position, but there are currently no playing problems, and about 80% of the frets remain. The remaining bridge saddle is about 2mm on the 6th string side and about 2.5mm on the 1st string side, as seen from the bridge stand.
Neck condition: No major problems as of now.
There is enough room in the truss rod.
About 80% of frets left (a few string marks)
Country of origin Japan
String height on 12F 6th string: approx. 2.5mm, 1st string: approx. 2.0mm
CaseNon-genuine hard case (size differs from the body)
Item rank: B
Serial number:M024063
