How to date your Burny
What about SGs ? I was looking to buy one that the seller says MIJ, but I have my doubts. It has Super Grade on the headstock, but 3 screw truss rod cover, no pics of control cavity, or pup cavity. and a serial #FG04071986
Thanks
Thanks
That's most likely Chinese
jacco said:
Thanks
I'm thinkin you just saved me a few hundred.. Thanks
Here's pics of my early 90's (?) Burny. No codes on the pots...maybe because they're lefty?
[/img]
Here she is 8)
Ok then from the pots and your theory the year should be 1987 right?
If you want some pup and cavity shots let me know.
hi
i have been looking at my guitars pots ,,, orville greco and burny
so here are what my pots says
GRECO EGC 1982 POTS 504042 18K
GRECO EG 1981 POTS 104042 08K
GRECO EG 500 GOLDTOP POTS 104042 O3K-02N
GRECO EGC 500 1982 ..POTS 504042 10K-1NK ??
GRECO EGC 500 1982 POTS 504042 10K
GRECO EGC75 (TOKAI MADE) 500KOA 07K
GRECO EG450 1982 POTS 504042 18K
BURNY SG ANGUS YOUNG MODEL M500KOA 21K
GRECO EG500 1980 POTS 504042 04K .05K
BURNY RLG 50 82-84 M500KOA 31K-32K
GRECO SG SS600 P2 1989POTS 504042 96K
ORVILLE LPF 1994 POTS M500KOA 44K-43K
ORVILLE LPS 1993 POTS M500KOA 35K-38K
BURNY SG WINGED TRUSS ROD COVER VH1 PICKUPS A500KO B500KO
GRECO EGC 800 SUPERSOUND 1981 POTS 104042 06K
BURNY SG WINGED TRUSS ROD COVER POTS A500KO B500KO
GRECO LP JR (TOKAI MADE ) NO SERIAL ,, POTS M500KOB 15K
BURNY LP JR ROCK N ROLL M250KOA 07K
BURNY SG EARLY 80 POTS NOBLE 15A 250K
AND THERE IS NOT AND O IN THE POT CODE IT IS THE SIGN FOR OHM
BUT I DONT HAVE THAT SIGN ON MY PC
HOPE THIS HELPS ............. AND I KNOW I NEED TO POST PICTURES ,, BUT I CAN NOT FIND THE CABEL FROM MY CAMERA TO MY PC :-(
ALL THE BEST
OTTO
JDB said:
Here she is 8)
Mmm but old pots can always be reused in later guitars. I do not think Burny was still making the split diamond in 87, did they?
Udonitron said:
JDB said:
Here she is 8)
Apparantly they did.
I can't follow your thinking process here. If the 7 from 1987 is an old pot than that split diamond Burny should be later than 1987..
If you look at the pics of the white custom split diamond on page 1; it has the 9 pots. So Burny were even making the split diamond in 1989, which corresponds with the catalogs BTW.
Chris, just take a look at your guitars or at pics on the web of Greco's from 82-92 and Orville's & ObG's up to 92. 9 out of 10 times the pots correspond with the year of the serial number. The one left is a pot of the previous year. So yes, older pots were used but I have never seen pots older than one year in relation with the serial.
So Jacco,
I bought this 86-87 burny not knowing much about it other than a rough guess at the year from the split diamond.
Without taking the pups out could you tell me what pups should be in it and a model number ?
Thanks.
JDB said:
So Jacco,
Thanks.
Do you mean the black custom you posted above?
RLC-60 & VH-3 pups. From the top of my head they should measure around 8.1.
Couldn't help myself so took out the neck pup and took some snaps.
looking at other pics around the forum the pups could be L8000's???( no numbers on pups)
And the number at the base of the pup cavity is 1. 28 and a faint what looks to be a 6 which is not visable in the pics, would that mean 1986??
BobK said:
I bought the guitar a few years ago off Greg in Wales, he used to be a regular here. Posted under a word starting with ULI**** I think?
Cough!!! UITA actually. Tape on the split diamond, fake long tenons, VH1 stickers, home made stamped pots and a steady hand to re-drill routing shapes. That's just a couple of things I do to stir things up a little!!!!
Also looks to of had the pups out at some stage and some fresh looking solder on the pots ? Maybe had some other pups at one stage then the originals replaced?
Might be starting to buy into your method... pots that I removed from my split diamond RLC-65 are all clearly stamped 87 below the 500K ohm stamp.
