Ayer's Rocker
Collecting examples of these.
1985 Vol 11 catalog
1986 Vol 12 catalog
1986 1987 Special Issue Catalog
1987 Vol 13 catalog
Ayer's Rocker II
稀少即決19800円[TOKAI/トーカイ][’85製F.V.Xシ... - Yahoo!オークション
This is the " AYER'S ROCKER II /chrome plated" that came with the 1985 Tokai F65 . There is wear and deterioration commensurate with its age, but it is in relatively good condition. Accessories include lock nuts, studs, and an aftermarket 6mm arm as shown in the image. Please check the image for the condition. It cannot be used universally with other Floyd Rose types. All the screw holes and tremolo screw holes have been completed. Please check the image for the condition. Although we do as much cleaning and maintenance as possible, the successful bidder is responsible for any necessary maintenance and cleaning.
1980's TOKAI AYER'S ROCKER 5 Bridge / FERNANDES Head Crasher FRT-5 Saddle GOLD Tokai Fernandes Bridge Gold
Description of item​
【Description of item】
This is a bridge that combines the bridge plate block of the 80's TOKAI AYER'S ROCKER 5 and the saddle of the FERNANDES Head Crasher FRT-5 from the late 80's .
The biggest feature of this saddle is that you can finely adjust the string height using the set screw on the saddle.
This allows it to accommodate a variety of fingerboard radiuses.
The block is brass.
Stud pitch approx. 74mm, block height approx. 41mm
Compatible with 6mm diameter tremolo arm threaded type .
If possible, I think it would be better to use a tremolo arm that is long enough to reach the bend.
( For TAKEUCHI and FERNANDES FRT-8, etc.)
*Size measurements are for reference only and there may be errors.
I have taken it all apart and cleaned it once .
3 Since it is more than 7 years old, there may be scratches, dirt, rust, peeling of plating, etc.
1980's Tremolo Arm Gold for TOKAI AYER'S ROCKER 5
【Description of item】​
Tremolo Arm Gold for TOKAI AYER'S ROCKER 5 made in the 1980s .
This is a tremolo arm that has a length up to the bending part . The material is steel.
I think it is suitable for TAKEUCHI products and FERNANDES FRT-8.
On the other hand , I think the height is too high for the original Floyd Rose and FERNANDES Head Crasher.
Since it is over 30 years old, there may be some scratches, dirt, rust, and peeling of plating.
