1980s 1985 "For New Rockers" Ad (Japan)
FOR NEW ROCKERS
Bending machine for New Rockers.
FSD65S ¥65,000
SHIFT2001 Super Advanced Mechanism SHIFT2001 allows vibrato while maintaining harmony. The bend amount (pitch change amount is set independently for each string. Can be adjusted verticallv. Uses torsion bar springs.
•Astonishing long sustain with heat-hardened stainless steel rollers and roller play fine luning mechanism. No rippling.
•Ready-made strings can be used as thev are. String replacement is easy and quick. A fine tune mechanism that achieves a smooth and wide effect. Adjusting screws are laid out in the best ergonomic position. Ultra-precision miniature bearings are used. Adjustable arm angle.
•Arm lock brake adjustment does not require adjustment tools. By using SHIFT2001 machined holes in the body became unnecessary. As a result, partial resonance disappears, and the original characteristics of the body material are utilized 100%. Clear sound from bass to treble
SPECIFICATIONS
•Body: Sen Alder
•Neck: Maple 1-piece U shape
•Fingerboard/22 frets, 400R rosewood
•Frets: Wide frets
•P.U.: Perr type P.U.x2 Escutcheon/Chrome
•Controls: 1 volume 1 tone
•Toggle switch
•Peg• mini rotomatic
•Vibrato unit: SHIFT2001 ETlock nut
•Colors: ABR (all black) ASWR (all snow white) AMRR (all metallic red) APPR (all pearl pink)
•SHIFT2001 is answer acoustic Lab product
High cost performance model for New Rockers.
TST36H ¥36,000
SPECIFICATIONS
•Body: Sen Alder
•Neck Maple U shape
•Fingerboard: Rosewood
•Peg covered type
•PU Dynamic57 x 2
•Controls: 1 volume, 2 tones
•Bridge etc SS unit chrome
•Pickguard: bra 3P
•Colors: ASWR (All Snow White) ABR (All Black) AMRR (All Metallic Red) ABBSR (All Blue Black Sunburst)
