1981 Parsons Bender Breezy Replaced Neck
1981 TE150 ?
Replaced neck... :-?
S/N 1015839
https://www.ebay.com/itm/1254953791...b_vTl8uRJe&var=&widget_ver=artemis&media=COPY
Description
This model is a Telecaster made in 1981. It is a very rare model equipped with a string bender, which was produced in limited quantities during this period!
The body is made of Sen, which was used in many guitars of this period. The wood grain and characteristics are similar to those of ash wood and match well with the blond color.
The neck has been replaced from the original. Original tokai logo pegs are installed. (According to the previous owner, the neck was custom-ordered by ESP.)
String bender is a system that Clarence White commissioned Gene Parsons to create in order to reproduce the nuance of pedal steel guitars.
The pitch is changed by moving the moving part of the lever on the strap on the neck side.
The guitar is in relatively clean condition for its age, with no significant scratches. The neck is currently almost straight, but there is no room to loosen the truss rod. The frets are about 80% full, so it can still be used.
This is one of the rarest and most rare guitars on the market.
The best deals often sell out in a day or two, so the sooner you get it, the sooner you can buy it.
Please forgive us if we sell out.
Body : Sen
Neck : Maple
Fingerboard : Maple
Scale Length : 25 1/2" (648mm)
Control : 1Volume, 1Tone, 3-way Toggle
Frets : 21
Pickups : Original
Weight : 3.955kg
