Works Bass Models
Bass Revolution
Works
Produced by TOKAI
Featured WORKS See Through Red model.
Lightweight & compact scoop out body realizes ideal playability.
The low impedance PU employs a low-noise. wide-range EMG, and in combination with the control system mentioned above, the potential energy that leads the sensibility of the player to a higher dimension is somelhing unique to WORKS. Intellectual electric that is most suitable for diversifying contemporary music.
TW-1501.
WORKS TW-1501 ¥150,000
• Body:Maple
• Neck:Maple
• Fingerboard:Ebony
• Bridge:Original design (Brass)
• Pickups:EMG or KENT ARMSTRONG
• Control:Balance control, Master volume, Bass boost,Treble boost
• Finishes: N, STR, STBL
THE FIRST ROUND CAMPAIGN
U.S. MASTERS FROM TOKAI
•Period November 21, 1986 to January 31, 1987
•During this period TOKAI Electric Guitars & Belize, HAMER Electric Guitars, CF MARTIN Guitars, CAT'S EYES Guitars, GRETSCH Drums purchased at the reqular price of 50.000 yen or more. We will give you an original telephor card.
First 1000 people, upon arrival of user card.
Tokai Gakki Co Ltd
1986-1987 NEW/ Catalog 11th. Name, Telepnone-MI.2L†
430 Wakimachi 36 Higashi Co., Ltd. YG12.
0815-1 Rare Cutout Tokai Advertisement Tokai Base Works
1987 Vol. 13 catalog
Rare Works(TOKAI) Electric Bass TW37 MBS Metallic Blue Sunburst Bass Revolution Works Tokai Revolution TW-37 Tokai
Description of item​
specification●Body: Agathis (Arched Top)
●Neck: Maple
●Fingerboard: Rosewood
●Frets: 24
●Nut Width: 38mm
●Controls: 1vol, 1tone, 1bass, Active Circuit
●Pickups: MFR-4
●Scale Length: 34" (864mm )
●Bridge: P-90
●Hardware: Chrome
●Color: Metallic Blue Sunburst
accessorieslock pin
Product conditionThis is an electric bass from Tokai Musical Instruments' export brand "Works".
It is probably a model from around 2000.
The strap pin has been replaced with a lock pin, but
everything else is original.
There are some scratches and scratches on the bottom and bottom of the body, and
there are small paint chips on the head.
There is no noticeable damage.
Although the frets are slightly worn, the wear is
only mild, and the neck is slightly warped, but there
is still plenty of room for the truss rod.
There are no problems with the electrical system.
If you are looking for one, please take this opportunity!
*The actual color may differ slightly depending on the lighting, shooting angle, and monitor.
*If you would like to add images, please feel free to let us know in the question column.
*If you have any questions, please write in the question column. I will answer as much as I can here.
