ST Timeline 1977- Present
Rough timeline for ST serial numbering systems:
1977- 1982: Date based serial number system
The Earliest Springys 1977-
1980-1981 Some Tokais models made in Nagano
Tokai In Nagano 1980, 1981
1982- ? Humbucker Telecasters with six digit serial number 10xxxx
Six Digit Serial Numbers Starting with 10xxxx
1982-1986: Fender style model based serial number system beginning in February 1982
Fender Style (Flat Top Series) Serial Number System (1982-1986)
Fender Style Serial Numbers Ended When?
Late 1982-1983: Export logo TST-56 & 62 guitars.
The Export, Transitional or "7okai Fat-Script" Logo
TST-56 Gallery
TST-62 Gallery
Late 1982/83: Script logo appears (outside UK?)
3 Piece Script Logo Goldstar Decals 1982/83
Late 1982: Block logos appear in the UK
1982/83 Block Logo Gallery
Mid 1983 Script logo appears in the UK & new Vintage MKI (V) & MKII (VII) pickups appear
1983 Goldstars Script Logo
VII ( Vintage MKII ) ST Single Coil Pickups
1983- Extra Tokai E.T.
"Extra Tokai" ET
Featured in mid year 1983 catalog
1982 - 1983 Springy to Goldstar transition
1983- Super Edition TSD & ASD
Super Edition TSD & ASD Guitars
1984-85 ? Hard Puncher, etc. six digit serial numbers 10xxxx
1984- Limited Edition TST Models
Limited Edition TST Guitars
1985- Custom Edition Models
"Tokai Custom Edition" Guitars
1985-1986: Some five digit serial numbers (2xxxxx) on lefty Goldstars.
Five Digit Non-Fender Serial Numbers On Tokai Strats
1985-1986: Six digit serial numbers appear starting with 11xxxx for non traditional Strat type guitars in the Limited Edition, Super Edition, and Custom Edition, lines.
Six Digit Serial Numbers Starting With 11xxxx
Early 1986: Fender style serial numbers end.
Early 1986 Six digit serial number starting with 2xxxxx
Six Digit Serial Numbers With 2xxxxx 1986 1987 1988
1989: Five digit serial numbers starting with 1xxxx.
Five Digit Serial Numbers 1xxxx 1989 1990 ?
1991-1994 ?: Six digit starting with 01xxxx
Six Digit Serial Numbers Starting With 01xxxx 1991 1992
1994-2009: Big blank spot during Fender production? Low spec Korean models no numbers, Chinese have serial numbers.
Tokai "Made In" & "Crafted In" Fenders
1996-2005 Korean production of most Tokai branded AST models
Korean Stamped Etched Impressed Neck Plate Serial Number Guitars
Early to Mid 2000s: All caps “MADE IN JAPAN” inked on heel of neck, and no serial number.
All Caps MADE IN JAPAN No Serial Number Guitars
2005-2009: Upper and lower case "Made In Japan" inked on heel of neck. No serial number.
Upper And Lower Case "Made In Japan" No Serial Guitars
2005- Chinese AST models
Tokais Made In China
2009- present: date based serial numbers inked on heel of neck similar to Fender.
2009 Goldstars
2009, 2012: Special order Springys commissioned by Faber Germany.
Springy Sound Limited Runs 2009, 2012
1977
1977 ST42
SN 7000040
(0wner Hiro)
These pots were used on STs beginning at least in 1978.
Note: Above 1977 guitar appears to have replaced pots.
1978
ST80R S/N 8000506
https://www.ebay.com/itm/2656466032...b_vTl8uRJe&var=&widget_ver=artemis&media=COPY
1984 AST Goldstar?
These apparently existed at the same time as the TST/AST-56 and 62 which had a V neck and rosewood slab respectively.
Tokai Goldstar Sound Strat Stratocaster MIJ 1985 1986 Lake Placid Blue w/tweed hard case | Reverb
(Voidoid56's photo)
From a 1985 TST50
Note: Non traditional guitars appear with six digit serial numbers beginning with 11xxxx. Notably Limited Edition, Super Edition, and Custom Edition guitars.
Note: Fender style serial number system ends in the spring of 1986.
Note: Six digit non Fender serial number system in the following format (20xxxx, 21xxxx, 22xxxx) apparently dating from the following post 1985 period having the - (hyphen, dash or minus) symbol in the production code. Known examples date from 1987 so far. Likely 1986 and 1988 as well.
Tokai Goldstar Sound TST-60s 1984 Cream White Fender Stratocaster reissue | Reverb UK
Tokai Goldstar Stratocaster Olympic white | Reverb
S/N 209815
Note: Still has brass grounding plate.
Note: Brass ground plate has been phased out by the time this guitar was made in 1987.
Brass Ground Plate
Voidoid56:
S/N 222587
  • V II pickups and Klusons so should be TST-50GS (despite 1954 detail, like a button string tree)
  • Pot codes are March 1987
  • Final Prospec bridge
  • Production codes separated by a dash, not =
  • Routs without pickup screw indentations, no control brass plate
  • Neck stamp is 5 -17, body stamp lost to screening paint
Actually one of the nicest STs/TSTs I've had.
Six Digit Serial Number Goldstars, Etc. Fender Headstock
Other guitars with the hyphen, dash or minus sign in the production code:
The Mystery Of The - Hyphen, Dash, or Minus Sign
Note: Yet another serial number system. This is a 5 digit serial number on a guitar with a rosewood board. Obviously no longer the Fender numbering system or this would begin with an L.
ST28 BBR
Tokai Custom Edition ST-Style zu verkaufen
1989 catalog
More “Tokai Custom Edition” guitars:
SN 12824
5 digit serial number.
Pots date to Sept 1989. (99).
Assembly of guitar in November (11) with 11-14 body code.
Some sort of odd paper label under the pickguard that possibly relates to a re-seller.
84 Goldstar?
1990 catalog
Only shows ST30/40/50
Low priced models (30,000 - 50,000 yen)
Note: Yet another serial numbering system. This is also 6 digits, but on HSS/SSH models in this period they have serial numbers that begin with 01xxxx and ususally have an "S" pencil ma\rked in the neck pocket.
HSS, Fender headstock, 6 digit SN, - instead of =.
SN 017895
tokai
Help rare Tokai Goldstar Sound
Other HSS Goldstars:
Mystery HSS SSH Goldstars
Circa 1994 AJB55
Same "S" mark in the neck pocket as the above HSS Goldstar.
Similar serial number to HSS Goldstars, six digit number starting with 01xxxx.
SN 015380
Tokai AJB-55 1994 Natural | Reverb UK
1998 catalog
Korean models (28,000 - 33,000 yen)
1998 - 2000 catalogs only show low spec models like AST 25/28/33 which are presumably made in Korea.
SN 190578 ?
Don''t think it is a TST50 as advertised...
Description
The absolute hammer! After almost a year of waiting, we couldn't wait to receive this Custom Order Tokai. We are presenting the guitar in a small number of pieces and absolutely exclusively for the Swiss market with the following ingredients: Body - light swamp ash with 60's body shape with a beautiful shimmering blonde finish Neck - one-piece fat C-shape neck with 9.5" radius and in flamed maple and beautiful tinted vintage finish and of course with original F***** headstock hardware - from Gotoh and kept in gold throughout. Try it out immediately and give yourself a huge gift is the order of the day. The photos may not correspond to the guitar in stock. Please ask us for photos of the available instrument.
Tokai TST 50 | Reverb
