MattThorpe
I bought a brand new Tokai LS150F (2008) recently and have been amazed at how good a replica of the Gibson LP it is. However, my Gibson LP has an early 70s DiMarzio Super Distortion Humbucker in the neck postion, which I am clearly used to, and so in comparison, I had been pondering changing the Tokai stock pickup. The Tokai pickup has a nice raw edge to it when pushed hard but I was convinced that overall it seemed quieter with less bass end.
I set about conducting an experiment. I recorded two similar guitar solos into my PC both guitars played through exactly the same Line6 POD setting, recording level and with no compressors in the patch or anything like that! The DiMarzio waveform looked slightly louder (wider pattern) which I was kind of expecting.
I then decided to see how long chords would ring out on each guitar to see if the sustain of the Tokai with the deep tenon neck joint was actually any better than the Gibson that is without this feature.
The waveforms showed that hitting a chord and letting it ring resulted in a longer sustain on the Tokai. I tried this several times and even if I hit the Gibson harder than the Tokai the Tokai still rang on longer.
In case any of you are wondering if it's all hype about Tokai's - it's all true they really are better! Those of us who know this are all very happy people :lol:
It would be interesting to try the Tokai LS150F against a Gibson LPS VOS 1959.
Anyway enough of this I have to go and play my Tokai ......
