cobra8272 said:
What upgrades are recommended if any.
I've read that stopbar, bridge, pots and nut should be replaced.
Is this correct and if so what should i upgrade with?
In general:
don't change anything if you like the guitar as is.
In special: i have a late 80s/early90s Burny Super grade, and the pots are excellent!
I can't recommend to change such great pots.
I changed the stopbar to an alu stop piece. It slightly changed the sound. It is just a matter of taste what sound you prfeer: the iron stop piece or an alu stopbar.
The nut of my Burny is quite ok, but i do not know whether its original or already an upgrade by a former owner.
What i did change was the pickups. Especially my bridge pPU sounded great when clean but for my taste too weak when overdriven. Thats just a matter of taste.
Now i have a DiMarzio AirNorton zebra in the bridge position and i am quite happy with it. More output than the original bridge PU, but not too hot (output is less than a JEff Beck), lotsa mids, but not mushy. The AirNorton in teh bridge is almost perfect for my taste.
I tried 2 neck PUs (Rockinger PAF ETC, DiMarzio Virtual PAF Neck zebra). I didn't like the Rockinger (although it is a great PU) in my Burny. The Virtual PAF is ok. It needed some fixing (lower on the bass strings, higher on treble strings). Now it sounds ok, but i still think about re-installing the original Burny PU.
To put it short: the only change I needed to fit my sound was the bridge PU. I mainly play rock/metal/overdriven blues rock. The rest was quite ok and the pots are supperb!
See you
B. III
