Seller's description:
Burny RLG '59MODEL les paul Lemon Drop exhibition.
This machine, which seems to have been manufactured in the 1980s, is a popular model that faithfully reproduces the 1959 Les Paul.
The pickup is equipped with two "VH-1", which is still popular today. A clear and responsive sound that faithfully reproduces the sound of an old PAF from the late 50's.
In terms of the shape truss rod cover with wings , there seems to be a model called "RLG-70" in the catalog at that time , but " RLG-70" has a flame maple top specification, but this individual is flame maple. It is a machined top specification of solid wood (pure wood) of wood (tiger heather maple).
In addition, the back material is made of two pieces of high-quality straight-grained mahogany that looks like a single piece of mahogany, and the fingerboard is made of jet-black high-quality rosewood, and the inlays look like real shell inlays. Specifications, fret binding is also applied. It is a specification that is particular about the material.
The neck is a one-piece mahogany neck set with a deep joint.
The book-matched two-piece maple top houses the Fernandes original VH-1 humbucker that faithfully reproduces the old PAF sound of the late 50's.
Nickel-plated hardware enhances the vintage taste.
The thick and chewy sound is just like a Les Paul, and you can feel the goodness of the construction that is unique to domestic production.
It is also a beautiful individual that can represent a jumper vintage with its excellent specifications and construction.
If you are interested, please consider it.
(Main Specifications)
BODY: Maple 2pcs Top / Mahogany Back
NECK: Mahogany
FINGERBOARD: Rosewood 22F
PICKUPS: Fernandes VH-1 x2
CONTROLS: 2Vol, 2Tone, 3WayToggleSW
BRIDGE: TOM w/ Stopbar
TUNERS: Vintage-type
HARDWARE: Nickel
As for the appearance, there are dents on the edge of the body top where the paint is peeling off (complementary color touched up), and small dents on the back of the body and the tip of the head. There are no other noticeable scratches.
The metal part has been polished, including each screw and bridge piece, and is in a generally clean state. (Please check the image for the final appearance condition.) There is also a [VH-1] sticker on the pickup escutcheon.
Currently, the string height is 12F, the 6th string is about 1.8mm, and the 1st string is about 1.5mm.
The nut width is 44mm.
Total length: about 101cm String length: about 63cm Weight: about 4.1kg
About 80% or more of the frets remain, and the fretboard frets have been regularly maintained and cleaned, so they are in relatively good condition.
As an accessory, it comes with a hard case with an aluminum edge and a FENDER guitar pick as shown in the image.
