I've had this Goldstar ST50 since early 1987, and for about 10 years it was hammered professionally - 4 years of which were with The Pretty Things.
It was so hammered that the tuners wore out and the bridge rusted and grooved to the point a new string was guaranteed to break within half a set.
In those days I used 11-50 gauge.
A loud and tough band - so you had to dig in.
It is currently also on it's third set of frets.
So I replaced with a Gotoh bridge that seemed to fit ok around 94 or so - but I was never really happy with the guitar from that point onwards and it tended to stay in the case.
Step One was recently reusing the original Tokai steel block when I realised the Gotoh was not steel - great(!)- some resonance and character came back straight away and I started liking it again.
Step Two was also realising that though the Gotoh was a perfect fit with regard to the six body screws, the actual saddles where a tiny smidgen wider.
This meant that cumulatively, the Low and High where nearer the edge of the neck the higher up the you went.
It was tiny, but perceptible from a feel standpoint.
Soooo, I set about cleaning the old saddles and plate and putting it back together.
Here it is before:
Then after a bit of filing, wire brushing and oiling:
And back on:
What a difference it makes!
Feels and sounds great again acoustically.
Hopefully the filing of the grooves will stop string breakage.
I'll also have to keep it dry after gigs and give a little dusting with oil to help stop corrosion.
Somehow it just seems *right* now, and I'm pleased one aspect of the guitar is back to original.
a few history shots of me and my old pal:
Here it is before:
And back on:
