2024 Models
Collecting examples of 2024 Tokais since there is not a catalog.
Documenting model numbers, etc.
Models
LS148F (CS, LD, IB)
LS144S (GT)
LSS136 (SYW)
LC156 (WR)
LS148F
SN 2449514
Tokai LS148F LD
MakerTokai
Product nameLS148FLD
List price including tax¥162,800
accessoriesSoft case warranty
Description of itemA pure Japanese vintage series made by Japanese craftsmen from wood selection to assembly.
A classic Les Paul model with the classic specs of maple top, mahogany back, mahogany neck, and rosewood fingerboard.
LS148F with beautiful heathered flame maple on the top.
This is a piece that has been carefully made over time, with excellent processing accuracy and neck fit, using traditional glue bonding.
The pickup is equipped with Tokai's original humbucker PAF Vintage MK-2S, which outputs a very clear tone and faithfully outputs the well-balanced sound of each string obtained from careful construction!
Perfect for those looking for a high quality domestic Les Paul model.
LSS136 SYW
SN 2449349
Tokai LSS136 SYW
Description of item​
This is a vintage series made in Japan, where everything from wood selection to assembly is done by Japanese craftsmen.
The highly popular Les Paul special type!
A traditional wood material with a mahogany body, mahogany neck, and rosewood fingerboard is equipped with two P-90 type pickups.
It also has an attractive look full of vintage taste, such as white-headed Kluson style pegs, fingerboard binding, and wrap-around tailpiece.
The single coil sound with a strong midrange allows you to play comfortably from edgy tones to thick and thick lead tones.
For those looking for a high quality domestic Les Paul model!
LS144S
SN 2449434
Tokai LS144S GT
This is a vintage series made in Japan, where everything from wood selection and processing to assembly is done by Japanese craftsmen.
Les Paul style is generally equipped with a humbucker PU, but this model is a so-called 1954 style Les Paul type that is equipped with a P-90 type PU and uses a gold top color.
Set neck specification with maple top, mahogany back, mahogany neck, and rosewood fingerboard.
The PU is equipped with two Tokai original LP-OLD MK2.
It has a distinctive thick edge, and you can enjoy a sound that is a little different from normal single coils and humbuckers.
LC156 WR
SN 2449394
Tokai LC156 WR
Tokai's VINTAGE SERIES is made entirely in Japan, with everything from wood selection and processing to assembly being done by Japanese craftsmen.
The neck material is a one-piece mahogany set neck, and the body material is maple top and mahogany back.
In addition to the finish, the pickup is equipped with the "PAF-Vintage MK2S" series, making it an uncompromising piece in terms of sound.
If you are looking for a domestically made guitar that is usable, please give it a try.
LS148F CS
SN 2449431
Tokai LS148F CS
This machine is laminated with flame maple, and the wood grain and color combine to create a gorgeous finish.
The PU is equipped with two Tokai original PAF-Vintage MK2S.
This is a product that gives you the feeling of being particular about being made in Japan, and there is no compromise in terms of sound.
