1997 Bacchus BLS-95
Puck Luck
Tokai Supporter
Centereach,NY
1997 Bacchus BLS-95
Completely taken apart and restored. 1k shipped and insured
It has a 3pc back, 95% one main piece and a small sliver of wood on each bottom end of the main body piece. You can only tell by carefully looking from the sides. Fresh fret level, crown and polish, fingerboard cleaned and inlays polished, tuners cleaned and lubed, pickguard, entire body and all hardware polished up as best I can. No dents or big scratches on the top and one hard to see small dent on the back, a couple of small scratches around the sides. Had a few chips on the bottom side poly, one that is still visible after I filled it but it's much less noticeable and totally smooth now. Comes ready to go with new 10.5 stringjoy strings and a used gibson case.
Current pics and restoration process pics on my site.
https://guitarrestos.com/bacchus-guitars/1997-bacchus-rlg-95/
Weight: 9lbs on bathroom scale
Neck Pickup: 14.93k, 34.12H / Bridge Pickup: 15.1k, 35.4H
Nut Width: 1.725″ / Thickness @ 1st fret: .864 / Thickness @12th fret: .949
