ES-120 Wiring
Vaughan
Oxfordshire UK
Does anyone have, or know where I can find a schematic for the ES-120 for reference. I've tried to work it out with a mirror through the "f hole" but the wires are a bit tangled.
This is just in case anything breaks.
Thanks
Try this:
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=2h_2v_2t_3w
There are loads of wiring diagrams on the SD site.
http://www.gibson.com/Files/schematics/sheratonII%20wiring.JPG
Try this link, I found the Epi diagram the most easy to follow
I re-wired a Tokai ES 130 recently with CTS pots and Tonerider pickups - here is a link to the page I made to illustrate it.
http://www.kevinyates.com/ES_335_re-wire/index.html
Good luck
Hi Kevcaster
This schematic looks just the job. I've had a look at your photos and I've made somenote for future use.
I had problems with the common ground but the fault has been cured by tightening all the control nuts.
Thanks for your help
