Tokai Pbass
APH
Is there anywhere to find out the year of manufacture of the bass. The serial number is 203449. thanks!image.jpg
That is a six digit it sounds like?
If so, can you post a picture of the neck plate?
That serial number range should be 1986 if it is 203449 and on the neck plate.
If it is on the neck heel and in ink then it is 2020.
You’re welcome. I’m assuming that serial number is correct and that it’s on the neck plate. If so, it should be a 1986 bass.
If you have pics of the pots that would probably date it too if they are original. Should be a two digit number on the pots starting with 6.
Hi again! What year is serial number 7110073 from? This is also PBass. Thank you!
Any time you ask a question about identifying an instrument we really need to see pictures to identify it. And it would be best to start a separate thread for a separate instrument.
