CE1200T Cat’s Eyes - 000 Size
1981 CE1200T
SN 1347481
Cat’s Eyes ’81 CE-1200T
Product description​
Cat's Eyes "CE-1200T 1981"!
"Cat's Eyes" is an acoustic guitar brand launched in 1975 by Tokai Gakki, a company also famous for its electric guitars.
Tokai Gakki became the sole distributor of Martin in Japan in 1972 and formed a technical partnership with Martin, allowing Cat's Eyes to utilize Martin's technology and produce many highly refined models. It shows that the craftsmen of the time produced products of the highest quality with outstanding technical skills.
This "CE-1200T" is an OOO-28 style model that uses high quality materials that were only available in Japan at the time.
It has a flower pot inlay on the headstock and herringbone around the body, giving it a very luxurious feel.
The top is solid spruce.
The sides and back are rosewood.
The neck is mahogany.
The fingerboard and bridge are ebony.
The headstock has a mini flower pot inlay.
The body is herringbone-finished.
The tuning pegs are Tokai Kluson type.
Long saddle.
Tortoiseshell pickguard.
The nut, saddle, and frets have been replaced.
A strap pin has been added to the heel side.
This is a high-end model made from very high-quality materials, so it has excellent quality.
After about 40 years, it has a very dry sound.
There is a "Martin crack" on the outside, which runs along the inside of the pickguard from the sound hole to the bridge.
There is also a crack at the bottom of the bridge on the top of the body, but neither of them have any gaps.
There are repair marks around the 4th string tuning peg post on the head.
There are no other noticeable scratches, and the overall condition is very good.
The condition is perfect, including the neck and frets, and it has been set up perfectly.
If you wish, we can install the pickup for free, just the pickup itself. We also have some used LRBaggs in stock. (New ones can also be ordered.)
    1.2 MB
    1.1 MB
    1.2 MB
    1.1 MB
    1.1 MB
    1.2 MB
    1.6 MB
    1.4 MB
    1.4 MB
    1.3 MB
    1.5 MB
1981 CE1200T
SN 1264580
Tokai Cat's Eyes CE-1200T 1981 Hard case included / All solid wood 000-28 copy model
(Added June 22, 2022 at 10:41)
Thank you for looking. This
is a used Tokai Cat's Eyes CE-1200T.
This "CE-1200T" is an OOO-28 style model that uses high-quality materials unique to Japan at the time.
The headstock has a flower pot inlay and the body has herringbone around it, giving it a very luxurious feel.
The serial number "1264***" suggests that it was made in 1981.
Top: Solid spruce
Sides & back: Rosewood
Neck: Mahogany
Fingerboard, bridge bridge: Ebony Mini
flower pot inlay on headstock
Pegs : Grover open
gear Long saddle
It is in good condition, but the frets have been rubbed together and there is no unevenness. I think there is about 40 to 50% left.
There is a crack along the pickguard from the sound hole on the top of the body to the bridge.
There is also a crack on the body top at the neck joint on the 1st string side.
There are repair marks near the 3rd string peg post.
The neck shape is triangular.
The string height is 3 mm for the 6th string at the 12th fret and 2 mm for the 1st string.
A Tokai original hard case is included.
This is a used item with signs of use, so please no claims or returns.
    1.6 MB
    2.2 MB
    1.3 MB
    2.2 MB
    2 MB
    1.9 MB
    2 MB
