Better than the real thing but what is it ???
Place to provide feedback for site improvements.
b2jgc
Post by b2jgc » Tue Jul 20, 2004 2:07 pm
I have owned several Fender telecasters over the years.
In 1990 I got hold of a well used second hand Tokai tele, butter scotch with a fender broadcaster maple neck.
Its electrics are noisy..BUT !!! Fantastic action plays like hot butter..screams like no other Tele ive owned. I played a session last month with this guitar and the other guitarist had a 66 original fender he estimated worth at ?2,500 gulp !! He ended up playing the Tokai ( with my permission) this seasoned session player said it was more tele than his ???
My guitar has a number on the neck plate of 1019309
what does this mean ?
Is there any other place I can look to find a Number that could lead to its age.
any help much appreciated
Cheers
jonC
ned
Post by ned » Tue Jul 20, 2004 2:25 pm
Check the main site (www.tokairegistry.com) or the FAQs section on the forum - you basically match the headstock and logo shape to the chart to get a close match on the date. We're still working on how to narrow down the Fender copies.
Ned
b2jgc
Post by b2jgc » Tue Jul 20, 2004 2:44 pm
Thanks for the reply BUT....
It has a genuine fender broadcaster neck and logo !!!
jonC
ned
Post by ned » Tue Jul 20, 2004 3:38 pm
Someone must have put the Fender logo on it, the headstock shape would indicate 1984 or older.
Ned
ian
Post by ian » Tue Jul 20, 2004 3:46 pm
Hi B2jgc - on Tokai Teles the neck-plate should have 4, 5, or 6 digits, but not 7. Do you know if the neck-plate is original to the body? What makes you think the body is a Tokai? Any cavity numbers?
Ian.
Ps ? the number on the neck plate just indicates which vintage Fender is being copied (eg 4 digits indicates copy of 1954-56 US Tele), it doesn?t actually indicate the date of manufacture like a normal serial number :-? .
b2jgc
Post by b2jgc » Tue Jul 20, 2004 3:49 pm
Thanks..what does the neck plate No indicate 1019309
jonC
b2jgc
Post by b2jgc » Tue Jul 20, 2004 3:52 pm
The guitar was advertised as Tokai also it has tokai on the bridge and machine heads what is a cavity No ????
jonC
ian
Post by ian » Wed Jul 21, 2004 2:02 am
Quote ?what does 1019309 mean?? ? well as I say, it appears to mean the plate &/or body are not Tokai, because the Registry doesn't list 7-digit plate-numbers. The Registry is not infallible though, & I wonder if that number might be from a 1981 7okai Breezy ? can you post some photos?
Quote ?what is a cavity number? ? almost all Tokai bodies (ie the Fender copies) have a characteristic style of number-code stamped in the pickup cavities, ie under the pickups. The number is in the form of one or two digits either side of an equals sign, eg ? 2=12 ? ? if you see numbers like that then the body almost certainly is Tokai (so far none of us know what those numbers actually mean) :-? .
Ian.
b2jgc
Post by b2jgc » Wed Jul 21, 2004 1:08 pm
Thanks for the info.
Ill take some pics.. cheers
jonC
b2jgc
Post by b2jgc » Sun Feb 27, 2005 11:25 am
ok I have taken it to bits and the only numbers on it are
on the neck in pencil under the varnish 7 26 82
thats it..
I have some pictures now but cant find how i should upload them for you to see please help.
jonC
