Greco finishes? What is Lacquer?
Axis
PostPosted: Wed Mar 20, 2019 6:20 am    Post subject: Greco finishes? What is Lacquer? Reply with quote
Is there anybody that knows what kind of finish Lacquer is? I have a EGC-1000 from 1981 and a friend of mine owns a EGF-1200 from 1980 and another one has a SA-1200. Its clearly says in the specifications in the catalogue that they all should have "finish-lacquer".
Is this a hybrid of poly and nitro or is it poly or something else. In some forums they say that Greco were using some kind of hybrid finish of poly/nitro, and some says it nitro with additive and some talks about pre cut nitro.
By the way, none of the guitars above do NOT react to aceton.
Is there anybody out there that could give any clarity to this matter.
PostPosted: Sun Mar 24, 2019 3:39 am    Post subject: Reply with quote
its nitro with additives to stabilise ..
Axis
PostPosted: Sun Mar 24, 2019 2:19 pm    Post subject: Reply with quote
Ok, is this why the finish not reacts to Aceton?
PostPosted: Sun Mar 24, 2019 2:35 pm    Post subject: Reply with quote
if you leave the acetone on long enough it will react... but not like pure nitro..
jumping@shadows
PostPosted: Fri Jun 07, 2019 2:50 pm    Post subject: Reply with quote
Having stripped and refinished a few vintage Greco’s, the finish is nitro-ish over a poly sealer/pore filler coat, and actually much thinner and harder than same era Tokai fwiw..
Seeking The Oldiest And Goldiest!
wulfman
PostPosted: Fri Jun 07, 2019 6:16 pm    Post subject: Reply with quote
Thanks for that first hand info, BTW your EGF-1200 restoration was amazing.
guitar hiro
PostPosted: Fri Jun 07, 2019 6:57 pm    Post subject: Reply with quote
to the OP:
the term 'lacquer' is a very generic, general term, which actually means nothing, because it could mean any thing.
https://en.wikipedia.org/wiki/Lacquer
