81 LS60 (Pics in post 2)
chuckyz2
PostPosted: Wed Oct 31, 2018 8:38 pm    Post subject: 81 LS60 (Pics in post 2) Reply with quote
edit:Added pics in next Post
Hi everyone.
I'm Chuck and I'm new
Just aquired a 81 LS60 in excellent
condition. Though I have read a lot
on here and elsewhere, I still have
a few q's about this guitar.
The Goutoh pickups, are they
as good as the Tokai labeled ones
that came in the LS80. And are there
other Tokai pickups besides those two
that are better still? I like the 59 Burst
tone and would like to get as close as
I can to resembling it.
The finish. I have heard it was Nitro
and that it wasn't Nitro. Which is it?
I'm a beginner player.
My player before this LS is a Samick
Artist Series LP 1999 Bubinga.
I really like the tone for what it is.
Warm. It has its limitaions though
and can get muddy. I am a beginner
hobbyist luthier and have aquired the
proper tools for fret leveling and after
doing the Sam it has a very low action
with no buzzing. I plan on doing the LS
soon but it is decent enough to play already.
The LS plays very nicely and the notes
chime just as I hoped they would. I have
a Marshall MG100 2009 on the half stack
it came paired with. 4x12 Not bad to start
on but already want some tubes.
I have leanrned a lot from this forum and would
like to thank everyone for there contributions.
81 LS60
View user's profile Send private message AIM Address
chuckyz2
PostPosted: Wed Oct 31, 2018 11:48 pm    Post subject: Pic added Reply with quote
81 LS60
chuckyz2
PostPosted: Wed Oct 31, 2018 11:49 pm    Post subject: Reply with quote
Deleted double post
81 LS60
Loudmouse
PostPosted: Thu Nov 01, 2018 10:37 am    Post subject: Reply with quote
Welcome Chuck,
Looks like a really nice guitar there. I would say a big step up from the Samick.
LS60 isn't nitro, I believe they are poly.
I like the gotoh pickups and would keep them for now and see how good they sound on your new tube amp.
chuckyz2
PostPosted: Thu Nov 01, 2018 2:34 pm    Post subject: Reply with quote
Loudmouse wrote:
Welcome Chuck,
It has upgraded Faber hardware. I have all the original hardware and it will always have the original pups even if I do try others looking for that old tone.
I watched 100's of vids of the bursts. All the 58 thru 60 and others that compare, or try to get that tone. All the different pups sound comparisons in R series Gibbo's etc. Being fully aware of the YouTube compression I know I'm not getting the full spectrum but have a pretty good idea of what I am hearing. And this LS60 sounds good even thru the SS amp. Cant wait to get a nice tube amp. The ones I want are out of my budget. Any suggestion on budget amps that get close to the Vox Doug and Pat have?
That will be my next study.
81 LS60
chuckyz2
Loudmouse wrote:
Welcome Chuck,
81 LS60
Loudmouse
PostPosted: Thu Nov 01, 2018 5:06 pm    Post subject: Reply with quote
Not really Vox-ey but I've always had good luck with Fender U.S.A. made Pro Jr's.
I've picked up a few used ones for dang cheap and they work great for the rack pre-amp I use(talk about old school haha). Two together = stereo fun.
I have a tweed Blues JR that is OK when just plugging the guitar in direct, no effects. Grab and go, sits with a band mix well and is plenty loud, has spring reverb and a footswitch fat boost that most people miss. Dime the master volume and use the channel volume and more importantly the guitar volumes for cleans up to full gain. A good variety of usable tones in a very portable amp.
The only Vox I ever had was an old solid state Scorpion 4X10.
PostPosted: Fri Nov 30, 2018 4:53 pm    Post subject: Reply with quote
Hi Chuck,
LS-60 is a brillinat starting point for Tokai Love Rocks.
- 1 pce Body, 1 pce neck, 2 pce solid maple top, POLY finish - not nitro.
Pickups are the Goto Dynamic around 8.6ohm, whereas the LS-80 used Goto Super. around 8.2 ohm. Hardware should be nickel but most likely chrome and the tailpiece should be aluminium (light) instead of Zinc alloy (heavy).
My major mod if you are chasing 50s tone is this:
[ 4 x Alpha 500k pots, 2 x PIO capacitors and wire to 50s spec.]
Your PCB board is wired to Modern specs so you lose tone and volume at varying stages.
I agree to run the stock pups for a while before deciding if you need a different pair, but the Goto's are pretty good.
regards
PostPosted: Fri Nov 30, 2018 11:29 pm    Post subject: Reply with quote
1 piece body? thought 60 was 2..
PostPosted: Sat Dec 01, 2018 12:05 am    Post subject: Reply with quote
Hi Mark
Not in 1981 they weren't. They didn't become 2 pce til around 1986
PostPosted: Sat Dec 01, 2018 3:26 am    Post subject: Reply with quote
thats strange, all the info says 2 piece back on the LS-60, I have not had one myself, but this has always been my belief..
J.E.M.
PostPosted: Sat Dec 01, 2018 7:06 pm    Post subject: Reply with quote
^This right here, I agree 100%
PostPosted: Sun Dec 02, 2018 7:53 am    Post subject: Reply with quote
I can see the seam on the back of this LS60 so it at least is a 2 piece back. Great axe anyway !!!
Nice that you got the case with it.
Congrats and enjoy !!
PostPosted: Sun Dec 02, 2018 10:06 am    Post subject: Reply with quote
I see it too ...
aroomstudios
PostPosted: Sun Dec 02, 2018 11:04 am    Post subject: Reply with quote
Peter Mac wrote:
I do the same but CTS 525k 5% pots (500k pots work fine also, but sometimes they can be as low as 460k or so that is why I use 525k 5% ones) , PIO caps and 50's wiring. Makes a HUGE difference. I normally do the women tone with the caps. 22nF in the neck and 15nF in the bridge. Though this is just preference though. I do Gibson style braided wire through out the guitar including redoing the 3 way switch with the braided wire. Sometimes I shield the cavities with gold foil tape sometimes I do not.
50's wiring picture
