SG
carl300367
PostPosted: Fri Oct 05, 2018 7:08 am    Post subject: SG Reply with quote
just got this today 4022696 is that 1984 has fret edge binding any info would be great
looks like a 2 peice back and not sure about the finish either poly or nitro
Mick51
PostPosted: Fri Oct 05, 2018 10:38 am    Post subject: Reply with quote
FEB. From that, I would guess a lacquer finish.
PostPosted: Fri Oct 05, 2018 11:15 am    Post subject: Reply with quote
Is it just me or does the headstock "open book" carve look exceptionally deep in the front facing photo?
carl300367
PostPosted: Fri Oct 05, 2018 11:17 am    Post subject: Reply with quote
yes it is quite deep
J.E.M.
PostPosted: Fri Oct 05, 2018 7:10 pm    Post subject: Reply with quote
I have an '84 TSG 50, the black one with the harmonica bridge and the headstock looks very different to yours and identical to LP's from the same year... I'm thinking maybe it was a very late 84 dimple model and the dimple has been removed?
Also interesting that it has FEB, not sure if 60 model LP's from that year also had it, I don't think so, but the cherry one was the higher of the two models so maybe... or could have been a special order higher model.
aroomstudios
PostPosted: Fri Oct 05, 2018 8:59 pm    Post subject: Reply with quote
Take one of the tuners off and dab a q-tip with acetone. Rub it where the tuner would go. If the paint comes off nitro if not poly.
carl300367
PostPosted: Sat Oct 06, 2018 4:36 am    Post subject: Reply with quote
Thanks for the help , i's just had strings on so when i replace i will check with acetone and check the neck pockets and pickups.
I think i got a bargain as I only paid 250 fo it
PostPosted: Sat Oct 06, 2018 9:23 am    Post subject: Reply with quote
Indeed, same here.
carl300367
PostPosted: Sat Oct 06, 2018 1:12 pm    Post subject: Reply with quote
Anyone got the same and could measure from the tip of the inlay to the bottom of the book carve?
J.E.M.
PostPosted: Sun Oct 07, 2018 8:32 am    Post subject: Reply with quote
Here's my 1984 TSG serial number 401xxxx
J.E.M.
PostPosted: Sun Oct 07, 2018 8:34 am    Post subject: Reply with quote
For reference here's my 1984 Love Rock serial number 401xxxx
PostPosted: Sun Oct 07, 2018 10:26 am    Post subject: Reply with quote
It looks like the entire top of the headstock has been recarved. The corners are far sharper (pointier?) than the other two headstocks. The right corner is below the dot of the Tokai I .... whereas the other two headstocks have the right corner slightly above the I.
The recarve due to the dimple headstock sounds plausible. Still a great SG though.... I don't think the recarve will affect the tone.
PostPosted: Sat Dec 01, 2018 12:10 am    Post subject: Reply with quote
The serial number is too early for dimple headstock plus dimple start shallowing over the top of the 'T" not after it.
I think this was a touch of customising. . . . .
