1984 Tokai Breezysound bridge pickup question.
spikeymikey
PostPosted: Fri Apr 27, 2018 6:37 am    Post subject: 1984 Tokai Breezysound bridge pickup question. Reply with quote
Hi there folks,
I have a 1984 Tokai Breezysound TE50. It's a nice guitar but was at sometime routed for a humbucker in the middle area just in front of the bridge pickup. It now has a DiMarzio Twang King in the neck which sounds really good and the original pickup in the bridge, which has since been wax potted as it squealed like hell.! The humbucker is not installed and there's just the hole under the pickguard.
I want to ask: What's the general opinion of the original pickups on one of these TE50's? I think this bridge unit sounds a little harsh, maybe kind of brittle so I'm thinking of getting it replaced. ALso the guitar lacks sustain despite the neck pocket being really tight. any suggestions on remedying this. It's a great player and has a two piece body.
Thanks in advance!
M.
PostPosted: Fri Apr 27, 2018 10:47 pm    Post subject: Reply with quote
Is the tone pot by any chance 1Meg?
spikeymikey
PostPosted: Sat Apr 28, 2018 4:04 am    Post subject: Reply with quote
Hi there Felix,
No, I've installed a 250K tone and volume. The volume pot was 1meg actually, for some reason? But when I got it , it was being used as an Esquire, with only the bridge pickup on the guitar. It sounded terrible unless the volume was full on!
PostPosted: Sat Apr 28, 2018 10:22 am    Post subject: Reply with quote
spikeymikey wrote:
Hi there Felix,
Hi
I asked because mine and I think also other Breezy's at that time (1980) came with factory original 1Meg tone and Vol. pots, talk about harsh!
It sounded much nicer once I had had some 250K pots in there.
spikeymikey
PostPosted: Sat Apr 28, 2018 1:13 pm    Post subject: Reply with quote
Right, thanks again Felix.
Yes, this sounds much better than it did since I put in the 250K's. Today I raised the pickup a little as I'd screwed it right down to try to tame it a bit when it had the 1Meg volume pot and it now sounds pretty damn good!
The DiMarzio Twang King sounds stellar in this guitar so I may still replace the bridge unit with one of these, but for now it ain't bad. Do most people leave the pickups alone on Breezy's do you know, that was kind off my original question?
Cheers
M
PostPosted: Sat Apr 28, 2018 11:25 pm    Post subject: Reply with quote
Cheers
M
I also did change the TEA (bridge) with a DiMarzio DP114-VT1 after placing the 250K pots on my Breezy.
