Greco Dry Z pickups readings help
pharold38
PostPosted: Mon Apr 17, 2017 7:14 pm    Post subject: Greco Dry Z pickups readings help Reply with quote
I have two Greco Dry Z pickups that I am yet to install in a guitar.
The mutimeter readings are 8.04 and 7.64.
Are these readings within the usual range for these pickups?
Would the pickup with the 8.04 reading be the bridge pickup?
Any info would be appreciated. Thanks.
PostPosted: Tue Apr 18, 2017 11:46 am    Post subject: Reply with quote
I guess yes. Dry Zs readings are usualy as noticed as far as they wanted to be PAFs alikes.
J.E.M.
PostPosted: Tue Apr 18, 2017 7:20 pm    Post subject: Reply with quote
Not sure about Z's but is the pole piece spacing the same, if not wider pole spacing goes at the bridge.
pharold38
PostPosted: Sun Apr 23, 2017 10:11 pm    Post subject: Reply with quote
Thanks for the info it is appreciated.
PostPosted: Tue Apr 25, 2017 9:52 am    Post subject: Reply with quote
yes thats about right the higher is usually in the bridge but its not always the case...
