Show me your pedal boards!
Goto page Previous  1, 2
Paladin2019
PostPosted: Sat Dec 04, 2010 5:58 am    Post subject: Reply with quote
A couple of years ago I went pedal crazy, then I went DIY pedal crazy, and finally pedal modding crazy. It lasted about 2 years and I've finally grown out of the unending quest for 'tone'!
The board is home-made, and deliberately laid out so that I can't keep adding to it. Self-control!
Chipps
PostPosted: Sat Dec 04, 2010 6:18 am    Post subject: Reply with quote
You've still got room for a couple of little pedals there
Can you run through what they all are? Are some home-made?
And is the top level on its own loop?
Paladin2019
PostPosted: Sat Dec 04, 2010 6:30 am    Post subject: Reply with quote
Three on the lower layer are home-made BYOC kits, each modded to my own specs. The way I have it laid out is that the bottom layer are all in the main line, and the top layer is the amp's FX loop and reverb footswitch.
We have a Crybaby 535Q Copper wah (modded by Stuart Castledine), a BYOC fuzz face, a modded Big Muff, a BYOC Rangemaster and a BYOC Tubescreamer. On top there's a MonkeyFX true bypass loop containing a DM3 analogue delay, modded CE2 chorus, and a Yamaha FL10 Flanger.
I refuse to have any more pedals or do any more modding, for the sake of my own sanity!
Chipps
PostPosted: Sat Dec 04, 2010 6:39 am    Post subject: Reply with quote
Nice.. I've made a couple of BYOC kits - a tremelo and a compressor and still use the trem a lot (the compressor needs some joints checking I think as it's gone a little inconsistent).
You have many fuzz boxes there - and JohnA thought it was greedy to have five distortions...
Paladin2019
PostPosted: Sat Dec 04, 2010 6:46 am    Post subject: Reply with quote
It's not that bad. One vintage fuzz, one modern high gain fuzz, one overdrive and one vintage boost! All the dirt bases covered.
PostPosted: Sat Dec 04, 2010 7:29 am    Post subject: Reply with quote
More pedals than a Quint!
butrus
PostPosted: Sat Dec 11, 2010 5:22 pm    Post subject: Reply with quote
my latest...
Chipps
PostPosted: Wed Mar 23, 2011 1:29 pm    Post subject: Reply with quote
I've gone pedal mental again! This time I obsessed about the tunes we have where I need a univibe and reverb one minute, and a dry but distorted sound the next. Or chorus and clean to crunch and delay and back again. Too much turning off of stuff and turning other things on in very little time, so I decided to justify to myself a Carl Martin Octaswitch. It's an eight input, eight channel pedal loop system.
So the pedals are all on and all feed into the Octaswitch. Then each of the eight channels has an eight-switch dipswitch, so you can tell it which effects you want on when you hit that switch. It's not an on/off system, as one channel is always on, so I have one set to clean.
So far it's been great - and (for once) just what I needed. The only problems (apart from actually fitting it in place is that I need twice as many patch cables! (The board is shown with the top deck removed while I was sorting out all the power and patch leads... Patch leads will be upgraded when I get time and money too)
Here's how I have it set:
1: Clean (or with long delay, which I'll manually switch in)
2. BOSS AC2 Acoustic Simulator + (extra) Reverb
3. AC2 with Modulation (I have all three modulation pedals on one patch as it's rare that I'll want them all on at once - so there's a choice of TC Vibrato, EHX Electric Mistress (set for Flange) and the Love Pedal Pickle Vibe.
4. Clean with Modulation
5. Crunch
6. Proctavia octaver
7. Rock! HBE Power Screamer + extra reverb
8. Guitar Hero - HBE + Reverb + Analogue Delay
Phew!
And now I reckon I want a TC Electronic G System!
I also am going to build a second pedalboard, with all my spare pedals, to be my blues board. Just an overdrive, delay, boost and reverb perhaps.
PostPosted: Wed Mar 23, 2011 3:33 pm    Post subject: Reply with quote
I see a lot of nice pedals here!
I've had 160ish pedals until last year when I decided to get a custom multipedal made by JAMpedals of Greece. And I still love it!
Needs just 1 9V adapter and weighs 2 kg
Chipps
PostPosted: Wed Mar 23, 2011 3:35 pm    Post subject: Reply with quote
I've seen this in another thread, haven't I?
Can you go through what all the bits do for us?
PostPosted: Wed Mar 23, 2011 4:11 pm    Post subject: Reply with quote
Yeah I think I posted it before somewhere..
Features from left to right:
bottom: A/B in, Boss TU-3 tuner, JAM DynaSsor compressor, JAM TubeDreamer72 transparant overdrive, JAM Tubedreamer58 tubescreamer, high gain switch for tubescreamer
top: JAM WaterFall chorus/vibrato, JAM Retro-Vibe univibe, JAM Rattler rat distorsion, JAM DelayLlama, delay, Wampler Faux reverb, A/B out
This is not the internal order of pedals btw.
There's a switch to get the tuner out of the circuit and a send-return placed after the distorsion to add some more pedals when needed.
All JAM pedals are true bypass and analog, love 'em!!
Page 2 of 2
