Honeyburst Super Real. Only EGF 1200?
Goto page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Sat Feb 09, 2008 5:34 am    Post subject: Reply with quote
ok .. the lacquer..
yellows with age normally, but can be very dark if exposed to sunlight and/or smoke...
as far as I am aware the nitro on all greco's starts out the same colour,
mick, its an 82 greco...so the closed O has been replaced by the open O of the mint collection...its a left over 1981 neck, still with the superReal logo on...(so they must have put the super real logo on before the greco logo in fujigen....)
the test to see if the body is superreal or mint collection is the tenon, if its a long tenon its a mint collection 82 body, if the tenon is normal LOOKING.. then its a super real...(also is long tenon ..but under the PU cavity so looks like normal)
so i have seen...
1. superreal necks and super real bodies with dry Z and the open O
(i have one on my site at the mo..the 82..)
2 superreal necks and mint collection bodies, open O, with the card saying EG58-120, even with the superreal logo, and Dry 1982,..
there was no actual manufacturing cut off point for superreals...they just sort of drifted into the mint collection....
still doesn't tell us the model no though....
EG58-120 is one guess, but the 3 piece body suggests a lower model number, so maybe a EG-58-100 which also had dry 1982....IF thats an original PU...
or it could be an EGF-850, with swooped PU's......LOL....
whats the tenon look like?
Mickdal
PostPosted: Sat Feb 09, 2008 5:43 am    Post subject: Reply with quote
Ok, thanks Mark
DNS
PostPosted: Sat Feb 09, 2008 9:35 am    Post subject: Reply with quote
You have too compare it to an 1982 year model.
This is:Greco Super Real EGF-1200
Honeyburst 3, 1982, at;
http://www.japanguitars.co.uk.
Mine at slightly different angle. I't also lacks some paint at the nut. And the tuners are changed. The nut might also be changed.
Edit smaller picture..
PostPosted: Sat Feb 09, 2008 9:38 am    Post subject: Reply with quote
yes thats mine ...with dry Z and a superreal body..
for the mint collection you can tell nothing from the Greco headstock logo..all the same ..so that could be a superreal neck on any mint collection or superreal body type...
.so still we are no further...
DNS
PostPosted: Sat Feb 09, 2008 9:49 am    Post subject: Reply with quote
Woops, you have been talking while i have been writing..
It's a long Mint Collection type neck joint extending in under the pickup.
Oh was there an EG58-100? Thought it was EG59-100 and EG58-120 what ever the difference might be..
I saw something when I examined my head: The truss rod cover differs from the ones I've seen on the net. Mine is stepped between the black and white layers and it seems the ones i've seen in the pictures have a flat angle.Is that understanable..?
But it might have been changed too, it has have an hard life this one. No extra screw holes though.
EDIT: Actually after some research the original gibson trussrod was stepped. And the only one without it is Villagers 1982 pictured in previous post. The other EGF's seem to have the stepped ones..sorry.
DNS
PostPosted: Sat Feb 09, 2008 9:59 am    Post subject: Reply with quote
What about the alu stoptail?
DNS
PostPosted: Sat Feb 09, 2008 10:19 am    Post subject: Reply with quote
Is'nt the main difference between the Super vs Mint bodys the rounded vs the flat carving in the pickup area on the top.
I would say I have a Mint neck with Super writing on head and a Super body.
Rather the best from two worlds..
PostPosted: Sat Feb 09, 2008 11:57 am    Post subject: Reply with quote
stoptail easy to change, truss cover same...
its not a mint neck...its a superreal neck...
and the body carve was never constant...
so....
do you have a pic of the tenon?
thats the only way to tell for sure if the body is mint or superreal...but the neck is superreal....
DNS
PostPosted: Sat Feb 09, 2008 12:55 pm    Post subject: Reply with quote
So which Mint models have the curved top? The EG58-120 is flat.
What makes my neck a Super Real if it has the extended tenon?
And whats the difference between a Super Real vs a Mint body exept the extended tenon, if not the curve cut.
PostPosted: Sat Feb 09, 2008 1:31 pm    Post subject: Reply with quote
no mint collection has a flat top..!!!
ll the mint have a carved top....as do the super reals ...the shape may differ from each guitar..but they are all carved....
the mint collection tenon looks like a normal long tenon...ie it extends into the PU cavity visably...the superreal body joint looks like that pic there...
but the pic you emailed me earlier was a mint collection type long tenon...
maybe you emailed me the wrong one?
there is no way of fully establishing what model you have....
DNS
PostPosted: Sat Feb 09, 2008 1:58 pm    Post subject: Reply with quote
The picture in my previous post shows a long tenon extending in under the pickup. Look again! No dowels either mind you.
It's a bit left in the "bottom corner", like a step but everything is the same piece of wood.
I'm sorry but I have only sent you pictures of the head and the body, none of the cavity. You have mixed up the pictures with somebody elses
Im not saying they weren't carved, read again.
Only the surface right under the pickup mounting rings is flat rather than curved. Curved as in unflat, not carved.
Like this EG58-120, which is rather flat:
DNS
PostPosted: Sat Feb 09, 2008 2:43 pm    Post subject: Reply with quote
This is mine. Curved. And dusty..
DNS
PostPosted: Sat Feb 09, 2008 2:55 pm    Post subject: Reply with quote
Another picture on the extended lip long tenon.
DNS
PostPosted: Sat Feb 09, 2008 3:46 pm    Post subject: Reply with quote
Which models had the alu stoptail as original equipment?
PostPosted: Sat Feb 09, 2008 4:44 pm    Post subject: Reply with quote
ah ok my error..wrong pics...
ok from that angle you can see the long tenon well ..so its a superreal neck, with a mint collection neck joint...
i see no relevance in the amount of carve...they all vary...
and no fret binding points to mint too...
Page 4 of 6
