Greco finishes? What is Lacquer?
Discussion area for Greco guitars
Moderators: ned, Grecomaniac
Axis
Post by Axis » Wed Mar 20, 2019 6:20 am
Is there anybody that knows what kind of finish Lacquer is? I have a EGC-1000 from 1981 and a friend of mine owns a EGF-1200 from 1980 and another one has a SA-1200. Its clearly says in the specifications in the catalogue that they all should have "finish-lacquer".
Is this a hybrid of poly and nitro or is it poly or something else. In some forums they say that Greco were using some kind of hybrid finish of poly/nitro, and some says it nitro with additive and some talks about pre cut nitro.
By the way, none of the guitars above do NOT react to aceton.
Is there anybody out there that could give any clarity to this matter.
Post by villager » Sun Mar 24, 2019 3:39 am
its nitro with additives to stabilise ..
Axis
Post by Axis » Sun Mar 24, 2019 2:19 pm
Ok, is this why the finish not reacts to Aceton?
Post by villager » Sun Mar 24, 2019 2:35 pm
if you leave the acetone on long enough it will react... but not like pure nitro..
jumping@shadows
Post by jumping@shadows » Fri Jun 07, 2019 2:50 pm
Having stripped and refinished a few vintage Greco’s, the finish is nitro-ish over a poly sealer/pore filler coat, and actually much thinner and harder than same era Tokai fwiw..
Seeking The Oldiest And Goldiest!
wulfman
Post by wulfman » Fri Jun 07, 2019 6:16 pm
Thanks for that first hand info, BTW your EGF-1200 restoration was amazing.
guitar hiro
Post by guitar hiro » Fri Jun 07, 2019 6:57 pm
to the OP:
the term 'lacquer' is a very generic, general term, which actually means nothing, because it could mean any thing.
https://en.wikipedia.org/wiki/Lacquer
