Help to identify Burny SG
Discussion area for Burny/ Fernandes guitars
tuskis
Post by tuskis » Wed Feb 21, 2018 1:48 pm
Hey all,
Recently, I purchased a nice Burny RSG off Reverb for a good price and now I'm wondering about it's exact make and model, seller assumed first 70's and then 80's. It's features are:
-Three piece mahogany body with a center seam joining the two main pieces together along with a small third "uh-oh the two halves are slightly too small" piece in the lower right of the body. Late sixties style shallow beveling.
-Seemingly one piece mahogany neck with rosewood fretboard and medium jumbo frets, no fret nibs and a volute at the back of the headstock, which angle seems to be 14 degrees. Nut width is about 40mm/1.5748 inches and the profile is pretty slim. Full Gibson-style crown inlay on headstock and Gibson style wide bevel bell TRC, not sure if original. It's joined to the body with a '66 style neck heel and a short tenon.
-Standard MiJ metric ToM bridge and tailpiece, eg. M4 bridge posts drilled straight into body.
-Standard SG-style control layout, original knobs were early sixties top hat style but I switched them for witch hats. Electronics cavity is the larger type but not fully rounded like on actual late sixties Gibson as well as usual Burny copies.
-Large "batwing" pickguard with two humbuckers. Pickup routing is like for a small pickguard though.
-Tuners have been replaced by Grovers at some point, not sure if originally was for 10mm tuners.
On paper looks like a RSG-75 '69 or the Angus Young AY model from the 80's, but the 70's style features like the volute and small neck are unlike those models judging from Burny's catalogs.
For other identifying features, the bridge and tailpiece both read SG BRIDGE/TAILPIECE MADE IN JAPAN under them.
Neck pickup has no markins so hard to say is it a VH1, can't measure DCR at the moment. Bridge has been replaced by a '57 Classic Plus at some point.
There's a small number in the neck pocket that reads 70911 along with a possible incomprehensible final character. There are no other serial numbers on the guitar.
Pots have some markins; JNOBLE 15A/B500Kohm
Here are some pictures: https://www.dropbox.com/sh/ce3u1ctk0vlv ... V1Xwa?dl=0 (don't mind the missing bridge pickup controls)
And here's the only similar model I found on sale online: https://www.digimart.net/cat1/shop3100/DS04134619/
Any help would be appreciated.
Thanks.
Post by brokentoes » Wed Feb 21, 2018 6:56 pm
Yeah it's an '87 RSG-75. ('69 model) nice axe. Angus Young model had a white poker chip. Serial number starting with "7" is the tell for 1987.
http://samurai-guitars.ru/catalogs/fern ... nandes.pdf
aroomstudios
Post by aroomstudios » Thu Feb 22, 2018 9:54 am
How do you like the burny SG? I have a 78' Burny FLC-85BL Les Paul Custom. I love this guitar. It is one of my favorite ones. Blows any Gibson Custom away. I had a late 90's Gibson SG years ago. It was okay but not great. I know Burny had their stuff made from all different companys. Tokai in the late 70's and so on. I heard Tokai made some of their guitars but not all of them in the late 70's. Not sure who made mine. No serial number on the back of the head stock on mine.
Anyways, how do you like the Burny SG? Anyone know what are the good years to get and the bad years etc?
Post by marcusnieman » Thu Feb 22, 2018 10:12 am
aroomstudios wrote: Anyone know what are the good years to get and the bad years etc?
The great years were when they came with the VH-1 pickups. 83 - 86 I believe.
tuskis
Post by tuskis » Thu Feb 22, 2018 1:34 pm
Thanks for the replies, '87 sounds about right and Google would agree with it as well. As such the neck PU is probably a VH-3 then. Maybe will have to source a VH-3 bridge as well.
As for liking it, I like it a lot, overall kind of hard to go wrong with any 80's Burny or Fernandes stuff, atleast on the more higher end of the price spectrum. The pencil neck suits me fine since I have small hands and not-so-coincidentally also really like AC/DC and Angus, the wood grain on this thing also looks a lot nicer than my 2015 Tokai and it just plays and feels great. Most likely though I'll replace the pickups with some T-top copies and upgrade the bridge to a TonePros nylon saddle ABR1, the nut may need some work too since it 'pings' a lot despite being bone. Also the electronics need a bit work too, the original knobs were REALLY tightly fitted on the pots so when I tried to get them loose with the 'ol shoelace method and applied a little bit too much force, the whole shaft of the pot came loose along with the knob...
I think this one was made by Matsumoku or Dyna instead of Tokai, but hard to say for sure.
aroomstudios
Post by aroomstudios » Thu Feb 22, 2018 2:49 pm
So, basically any model with the VH-1 PUs is good? Like this one?
https://reverb.com/item/7747804-burny-r ... 80s-cherry
Post by brokentoes » Thu Feb 22, 2018 2:57 pm
The routing on the op's SG is not Tokai.
As for the reverb link SG it's hard to know if those are the original pups, etc.... The fact that the seller can't count how many frets the guitar has doesn't inspire confidence.
aroomstudios
Post by aroomstudios » Thu Feb 22, 2018 7:27 pm
How to you tell the routing is Tokai? 24 frets I did not even see that. Pretty funny.
Post by marcusnieman » Fri Feb 23, 2018 8:04 am
On either side of the routing, you'll see the deep indentations - Tokai routing, they are square shaped, while the routing in your link shows them as oval.
Tokai routing:
https://goo.gl/images/k1M6Z1
aroomstudios
Post by aroomstudios » Fri Feb 23, 2018 9:47 am
I see what you are saying about the routing square vs oval. I just pulled apart my Burny Les Paul (which I love) it is has oval routing. I pulled one of my Tokai LS-80s from 81' to have a look and it is square just like the pic you posted. Here are a few more pics from the Reverb listing showing what the seller says is the VH-1 PUs.
From the below pics notice the oval routing (non-Tokai). Not sure if this matters though. I love my 78' Burny LP with is not a Tokai made one and it is one of my favorites even over my two 81' LS-80s. By the way the seller just told me it was 78' when I bought it. I have no way to prove it no SN. Which seems to check out on the internet for late 70s. Though it seems older that my 81' Tokais to me. So, 78' sound reasonable.
Can you be sure this guitar has the original pickups?
Trade Winds Inc Feb 22, 2018 05:25 PM
Pdk1gacpb3dvcbln83f2
I think guitar has the original pickups.
WOODSTOCK guitars Feb 23, 2018 02:54 AM
Factory wiring. These pickups correspond to the images of vh1 of that period on the internet.
WOODSTOCK guitars Feb 23, 2018 03:14 AM
Post by brokentoes » Fri Feb 23, 2018 10:37 pm
I didn't mean to say that since it didn't have Tokai routing that it wasn't a good guitar, i just was pointing out that it wasn't a Tokai made guitar.
If the pots are original to the guitar you can date a guitar within a year or so by the pot numbers on non serial number guitars. Wish i could help more.
aroomstudios
Post by aroomstudios » Fri Feb 23, 2018 11:00 pm
Do you know how to date the guitar from the pots? I know a lot or enough about Tokais. At least their LS series from 70' and 80's. I really do not know anything about Burnys. About stuff like this and what the good one to get are and the bad ones. The guitar I posted pics of above is for sale right now. If it was good I may make an offer on it.
It is listed as Burny RSG-75 80's model and nothing more. Though I cannot prove or look up any of this. I do not know if the VH-1 PU are actually VH-1 as there is only a sticker on the PU covers and not the PU themselves. Though I can see used VH-1 PU for less than $100 USD so either way they are cheep to buy later. I guess I care more about the wood and if it is really a good Burny and really a RSG75 and not a Chinese knock off. I know there are a lot of people trying to knock off Chinese made Tokais as MIJ LS-80 or so. That is why I learned to much about them a few years ago before I bought a few of them.
tuskis
Post by tuskis » Sun Mar 04, 2018 12:34 pm
Dating MIJ guitars from pots is probably a lost cause, I've never seen any asian made guitar use any sort of pot codes on their pots. However the guitar on sale on that Reverb ad is 100% MIJ, not a chinese Burny.
You could try to ask the seller about the pickups, eg. have they been replaced. Better yet, ask for pictures.
aroomstudios
Post by aroomstudios » Sun Mar 04, 2018 2:51 pm
Those are pictures of the PU in my post 4 above. The seller sent them to me. He said he thinks they are original but that does not mean anything. I think he is a dealer.
