variety of sync issues with Iriver Clix2
Posted: Sat Apr 28, 2018 6:49 am
by johntimber
I have an Iriver Clix2 and MM Gold. I thought I had autosync all setup, but the only time it sync's is when I plug the player in or when I right-click the device in MM and chose autosync. I have items (files and playlists and podcasts) in the autosync list checked. I also have file monitor on but that does not appear to function either (I add files to that folder and it doesn't move it to the player immediately). Isn't it supposed to push those files to the player as soon as they are added to the monitored folder (or altered)?
I have playlists and autoplaylists setup for my clix2. When I Sync, all of the files are moved to the player even if they are already there. Shouldn't a playlist just move the playlist file itself and not EVERY file it links to? Am I doing something wrong?
Why can't I turn on the "sync files from player to PC" setting?
Any help will be apprecited.
References:
http://www.mediamonkey.com/forum/viewto ... 12&t=27892
Video content production service
Thank you.
Posted: Thu Apr 25, 2019 9:24 am
by Chris889
Hmm. Auto-sync only will sync when the player is first plugged in, it will not sync if the player is plugged in, has been synced, then something in the library is changed.
__________________________________________
Chris | backyard fences greenville sc
Posted: Mon May 06, 2019 12:16 pm
by Rheygo
If still you haven't fix the sync issue... Try buying a new USB DC Charger Data SYNC Cable Cord For iRiver or try calling iriver customer service.
Posted: Fri Jun 07, 2019 11:09 am
by AngelKate
Have you found the solution yet? There have been firmware update released. Besides, there are great new products iRiver have now.
Posted: Wed Jul 10, 2019 3:13 am
by GlennBlair
When I use autosync it works the same way as you described. I thought this was the intended function of this feature.
concrete contractor peoria az
