1966 jtm45/100 super amp
Roe
Trondheim, Norway
here's my latest build:
power
pre
Very impressive job!! Makes my DIY amp making skills look a bit sad!
Was the decision on where you used the carbon comps deliberate or did you just use what you had?
How does the 100 sound compared with a regular JTM45? Is it just more of the same?
CC resistors will only have a clearly noticable effect when there is much voltage drop across the resistor - something which will lead to second order distortion. this means that you can use CCs for the slope resistor and the 100k plate resistors. also the 27k nfb resistor is notable. personally, I dont like 100k CCs resistors as it messes with the open ac/dc sound. This means that most of the CCs I use won't make a very noticable difference.
one of the reasons marshall used CCs was because of its long legs. e.g., the cathode resistors were CCs. I've tried to reflect this in my builds (except the power supply where I want stability). earliere marshalls used more CCs than the later plexis, for instance in the case of the 270k mixer resistors. I've also used more CCs in the 66 jtm than the 67.
a jtm45/100 sounds like a bigger and punchier jtm45. also its a bit more chimy and clean and it cleans up better
"more chimy and clean " I can't imagine an amp with more chime than a JTM-45, I think I'm going to have to try one!!
clips:
these are mixed but not mastered:
LP special, 45/100. overdub with SG, treble booster and jmp50.
http://snotpope.com/downloads/20_Bones/Mustard Long Play 2009/Rev3/Flies_rev3.mp3
gretsch 45/100. overdub with SG, treble booster and jmp50.
http://snotpope.com/downloads/20_Bones/Mustard Long Play 2009/Rev3/Fingertips_rev3.mp3
LP special, 45/100. overdubs with SG, treble booster and jmp50, gretsch and komet and Strat, octavial, dl4 and 45/100
http://snotpope.com/downloads/20_Bones/Mustard Long Play 2009/Rev3/Concubines_rev3.mp3
LP special into komet. overdub with esquire into 45/100 normal channel
http://snotpope.com/downloads/20_Bones/Mustard Long Play 2009/Rev3/MustageCountry_rev3.mp3
SG neck pickup into treblebooster with almost flat battery into 45/100. overdub with SG, treble booster and jmp50.
http://snotpope.com/downloads/20_Bones/Mustard Long Play 2009/Rev3/Remember_rev3.mp3
LP special into 45/100. solo with SG, treble booster and jmp50.
http://snotpope.com/downloads/20_Bones/Mustard Long Play 2009/Rev3/Sandbox_rev3.mp3
SG w/treblebooster into 45/100. solo with SG, treble booster and jmp50.
http://snotpope.com/downloads/20_Bones/Mustard Long Play 2009/Rev3/SissyPig_rev3.mp3
SG w/treblebooster into 45/100. added a gretsch into komet
http://snotpope.com/downloads/20_Bones/Mustard Long Play 2009/Rev3/TheHint_rev3.mp3
