reverb ST-80 can you guys let me know if you think genuine?
mbrambley
Active member
thanks in advance - im guessing there are some of you here who know what to look for
Thank you
https://reverb.com/uk/item/37630238-tokai-st-80-springy-sound-1978-black
Thanks!
according to this website (this one TGR) on the dating fender copies section it says ST80 serial number should be 4 digits
This information is from the 1982 Catalog.
Year Copied Tokai Model Serial Number Scheme*
1948~1954 Model
3 or 4 digits on bridge plate TE80
1954~Pre-1956 Model
4 digits on neck plates ST80, 100, 120
TE80,120 Serial Number 4 digits
1956~1960 Model
5 digits on neck plates ST50, 60
TE50, 70
PB80 Serial Number 5 digits
1960~1964 Model
L+5 digits on neck plates ST50R, 60R, 70R, 80R, 100R, 120R
TE50R, 70R, 80R, 120R
PB70R, 80R JB45R, 60R, 80R, 85FLR, 120R Serial Number L+5 digits
1965/1965~1976 Model
6 digits on neck plates ST70, SS60/60R
TE200R
PB40/40R, 48/48R, 60/60R, 70 Serial Number 6 digits
1976 Model
7 digits on headstock SS60/60R 7 digits on headstock
whats going on there then?
You are confusing yourself.
Why are you looking at ser # for 82 onwards when you are wanting to buy a 78?
The ser # system changed in 82 to reflect which model and era of Fender they were replicating.
1977/1978 Springy's are considered first year issues for them. They are unique in that the early issues (up to mid year 78) had narrow neck plates which will not fit a serial number as you've shown. The serial numbers were inked on the bottom of the neck heel and the model number inked in the neck pocket. Around mid 78, they went to the wider neck plate with the serial number stamped on it like yours. Your serial number does match up to these later 78's. Nice guitar - good price too.
