Can you help date a Breezysound?
Posted: Sun Apr 28, 2019 8:22 pm
by neener83
Hi there! So happy to have found an active Tokai forum. Awesome!
I've been trying to date my Tokai Breezysound for a few years with no luck. There doesn't seem to be much out there about my model. Also, I noticed there is no truss rod on my model which I found unusual for a Tele.
Any info would be greatly appreciated thanks!
(i dont know how to post photos so here are links, i apologize)
https://imgur.com/a/ROgkVJz
https://imgur.com/a/GYtxAvF
https://imgur.com/a/kAK9xrZ
https://imgur.com/a/AykZxzl
Posted: Mon Apr 29, 2019 4:40 pm
by Peter Mac
Hi neener83,
From the few photos you have sent I would put this Breezy as a TTE-60 RR probably made between 1983 and 1984.
Bridge does not look original though. Next time you change strings, unscrew both pickups as they should show a stamp like " TEB " on the bottom of them.
Take off the neck and you will find a phillips truss rod adjuster at the base of the neck with another stamp similar to " 5=12 ". Next go to the control plate and undo the 2 screws and lift it up. There should be another stamp similar to "5=12 RR Z" - or under the front pickup - both locations were used.
Take lotsa photos and post them and we can define exactly what it is.
regards
Peter
Posted: Mon Apr 29, 2019 6:10 pm
by neener83
Peter Mac wrote:Hi neener83,
regards
Peter
Awesome thank you for the insight. I've been meaning to pull it apart.
Out of curiousity, what makes you think bridge isn't original?
Posted: Mon Apr 29, 2019 6:48 pm
by Peter Mac
sorry. i just double checked and the first 2 Years did have a chrome 3-saddle bridge. Later Years had a 6 saddle.
Again, sorry for the upset.
regards
Peter
Posted: Fri May 03, 2019 11:15 am
by neener83
Peter Mac wrote:Hi,
regards
Peter
This might be a long shot, but an idea what Fender would be comparable size wise? The neck on the Tokai is perfect. It's on the thinner side for sure. I haven't been able to find a Tele that matches it.
