Quilted Top - Are they solid wood or a veneeer ?
-Alan-
Been thinking a bit more about the finishes on some of the Tokais I have.
The one that has me pondering most is the blue quilted one - similar to the LR105Q in the link brokentoes kindly posted below:
brokentoes said:
Well it's a 2004 for sure. They came in a few colours in your quilt.
I haven't been able to determine for sure whether the quilted finish is actually a solid piece of maple or a pretty veneer. I suspect the latter - but am still holding out a little bit of hope I'm wrong :)
Can anybody give me a definitive answer or even a steer before I start having to remove strings and pickups ?
Ah well..the dream was nice while it lasted.
Two veneered finish and one solid - could be worse :)
Just as an aside - I know Tokai made LoveRocks with solid (ie non veneer) flamed finishes: did they also make solid quilted ones ?
HHi guys,
I have seen only 2 Tokais with solid quilt tops - 1983 LS-200V and a 2002 LS-320.
The easiest way to tell is to take out one of the pickups and look into the cavity facing the scratchplate - not the bridge.
If the figure travels into the cavity and touches the mahogany, it is solid top.
Otherwise - and this is generally rule of thumb with quilt - it is veneer.
hope this helps
Peter
