JohnA said:The LS135 is a SEB (Sound Effect Body) model, i.e the back is made up of a lot af small blocks of wood glued together, it's quite obvious if you take a look.
If not, info like how many pieces the back is made up of (look carefully) will help identify the model.
Very pretty whatever it is
DaveWW said:Hi Guys,
You need to look at the side to see if an SEB. The back is 2 pieces but the middle section is made of small blocks. You can see the centre section on this pic of my old one
Dave
SkyNet3D said:http://www1.odn.ne.jp/tokaigakki/products/vintage/ls140f.html
I would say it's a LS135F, that is equivalent to the current LS140F.
DaveWW said:I think if you look closely you'll find it is a very/very thin hard to spot veneer. It will have a light alloy tailpiece and brass bridge saddles too if it was a L135F/140F. I'm pretty sure it's an LS95F. If you search you'll find a thread showing just how thin and hard to spot these veneers are.
Dave
