Image of pristine new wiring for a Springy from the 1978/79 catalogs.
The first domestically produced brass shield plate. Stable shielding effect for a long time Demonstrate. When wiring, variable To prevent the performance of the sister (variable resistor) from deteriorating due to heat during soldering work. A separate terminal is provided for the ST series and soldered to it. Therefore, maintenance The tone selector switch is a 3-stage switch. Adopted. Of course, '54 Strat halftone Is extremely easy to issue. The setting can be set quickly, and it will not fall out during the performance. (newly developed, 3 steps, 5 positions switch.
